[SCM] PostGIS branch master updated. 3.4.0rc1-959-g96fb256d7
Fri Mar 1 02:15:17 PST 2024
the project "PostGIS".
       via  96fb256d7f998621d490ae3e37987072c86634d6 (commit)
      from  340197426c7fcaa4b7e79c74cabd98a688cc6b89 (commit)
revisions in full, below.
commit 96fb256d7f998621d490ae3e37987072c86634d6
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Mar 1 11:14:30 2024 +0100
    Do not discard errors from loading sql files (run_test.pl)
    This was broken by previous commit
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 246a9546c..a3724bf82 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1591,7 +1591,7 @@ sub load_sql_file
         $cmd .= "-c 'SET search_path TO $OPT_SCHEMA,topology'";
         $cmd .= " -v \"opt_dumprestore=${OPT_DUMPRESTORE}\"";
         $cmd .= " -v \"regdir=$REGDIR\"";
-        $cmd .= " -Xf $file $DB 2>&1 | tee -a $REGRESS_LOG > $tmplog";
+        $cmd .= " -Xf $file $DB > $tmplog 2>&1";
         #print "  $file\n" if $VERBOSE;
         my $rv = system($cmd);
         if ( $rv )
@@ -1608,6 +1608,8 @@ sub load_sql_file
                 return 0;
+        system("cat $tmplog >> $REGRESS_LOG");
     elsif ( $strict )
Summary of changes:
 regress/run_test.pl | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
