[PostGIS] #5684: Segfault from _RegisterMissingFaces
PostGIS trac at osgeo.org
Fri Mar 1 10:34:33 PST 2024
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.5.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Comment (by strk):
 Instructions to reproduce:
 1. Download the attached issue5684.pgtopo
 2. Import with: pgtopo_import -f issue5684.pgtopo issue5684 | psql
 postgis_reg
 3. select topology._registermissingfaces('issue5684'); -- 3 times
 Here's the dance performance:
 strk=# select topology._registermissingfaces('issue5684');
 ERROR:  Polygonize: face table is not empty.
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5684#comment:2>
