[SCM] PostGIS branch master updated. 3.4.0rc1-967-g19b34383b
Mon Mar 4 08:44:57 PST 2024
the project "PostGIS".
       via  19b34383bc2bb5b824a8c970d8acf8984688ab3e (commit)
       via  3395dd4e97080ab361d1514efe9ce4c1a948eb2f (commit)
      from  5030132559cd8504b0343efa903752f38c59bcee (commit)
revisions in full, below.
commit 19b34383bc2bb5b824a8c970d8acf8984688ab3e
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Mar 4 17:44:17 2024 +0100
    Do not compare signed and unsigned
    See 07a73c0f2c5cb07e33fd64dadd24fac35efdc0a5
diff --git a/loader/shpcommon.c b/loader/shpcommon.c
index ec7946778..38e90e460 100644
--- a/loader/shpcommon.c
+++ b/loader/shpcommon.c
@@ -268,13 +268,20 @@ colmap_read(const char *filename, colmap *map, char *errbuf, size_t errbuflen)
     /* Error out if the dbffieldname is > 10 chars */
     if (strlen(map->dbffieldnames[curmapsize]) > 10)
-      if ( errbuflen <= snprintf(errbuf, errbuflen,
+      int ret = snprintf(errbuf, errbuflen,
         _("ERROR: column map file specifies a DBF field name \"%s\" which is longer than 10 characters"),
-        map->dbffieldnames[curmapsize])
-      ) errbuf[errbuflen-1] = '\0';
+        map->dbffieldnames[curmapsize]);
+      if ( ret < 0 ) {
+        /* output error - TODO: report via perror? */
+        return 0;
+      if ( errbuflen <= (size_t)ret ) {
+        /* output truncated */
+        errbuf[errbuflen-1] = '\0';
       return 0;
     ++curmapsize;
commit 3395dd4e97080ab361d1514efe9ce4c1a948eb2f
Date:   Mon Mar 4 17:00:04 2024 +0100
    Do not debug-print geometries in debug level 1
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index c3da57c02..630cace9f 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -5532,7 +5532,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   if ( tol )
     tmp2 = lwline_remove_repeated_points(edge, tol);
-    LWDEBUGG(1, tmp2, "Repeated-point removed");
+    LWDEBUGG(2, tmp2, "Repeated-point removed");
     edge = lwgeom_as_lwline(tmp2);
     if ( tmp ) lwgeom_free(tmp);
     tmp = tmp2;
@@ -5896,7 +5896,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
   if ( nodes ) _lwt_release_nodes(nodes, numnodes);
   if ( edges ) _lwt_release_edges(edges, numedges);
-  LWDEBUGG(1, noded, "Finally-noded");
+  LWDEBUGG(2, noded, "Finally-noded");
   /* 3. For each (now-noded) segment, insert an edge */
   col = lwgeom_as_lwcollection(noded);
@@ -5956,7 +5956,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     ids[num++] = forward ? id : -id; /* TODO: skip duplicates */
-  LWDEBUGG(1, noded, "Noded before free");
+  LWDEBUGG(2, noded, "Noded before free");
   lwgeom_free(noded);
   /* TODO: XXX remove duplicated ids if not done before */
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c |  6 +++---
 loader/shpcommon.c           | 17 ++++++++++++-----
 2 files changed, 15 insertions(+), 8 deletions(-)
hooks/post-receive
