[PostGIS] #5683: 32bit test fails on ST_SnapToGrid test
PostGIS trac at osgeo.org
Tue Mar 5 08:52:40 PST 2024
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:  regression
Comment (by pramsey):
 Hm, I see gitlab-ci doesn't run the cunit tests in liblwgeom, so I cannot
 see if my unit test works. Probably the set-up script doesn't install the
 cunit support before configure/build?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5683#comment:2>
