[SCM] PostGIS branch master updated. 3.4.0rc1-974-g376d4ec7c
Tue Mar 5 13:49:32 PST 2024
the project "PostGIS".
       via  376d4ec7caf5b3772a8615f7b44b880bf4942ef8 (commit)
      from  e691c963fdc83d36e5e18a4e7aca912867893759 (commit)
revisions in full, below.
commit 376d4ec7caf5b3772a8615f7b44b880bf4942ef8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 5 13:49:28 2024 -0800
    ST_NumInteriorRings for Triangle, references #5686
diff --git a/postgis/lwgeom_ogc.c b/postgis/lwgeom_ogc.c
index d4458462a..33ad57c8f 100644
--- a/postgis/lwgeom_ogc.c
+++ b/postgis/lwgeom_ogc.c
@@ -420,7 +420,7 @@ Datum LWGEOM_numinteriorrings_polygon(PG_FUNCTION_ARGS)
 	if ( !lwgeom_has_rings(lwgeom) )
 		PG_RETURN_NULL();
-	if ( lwgeom_is_empty(lwgeom) )
+	if ( lwgeom_is_empty(lwgeom) || type == TRIANGLETYPE )
 		PG_RETURN_INT32(0);
@@ -428,7 +428,7 @@ Datum LWGEOM_numinteriorrings_polygon(PG_FUNCTION_ARGS)
 	 * with an array of nrings rings of POINTARRAY holding the
 	 * rings
-	if (type == POLYGONTYPE || type == TRIANGLETYPE)
+	if (type == POLYGONTYPE )
 		const LWPOLY *poly = lwgeom_as_lwpoly(lwgeom);
 		result = poly->nrings - 1;
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 3c2bbe0a7..ad900d80a 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1553,3 +1553,5 @@ SELECT '#5677',
+SELECT '#5686', ST_NumInteriorRings('TRIANGLE (( -71.0821 42.3036, -71.0821 42.3936, -71.0901 42.3036, -71.0821 42.3036))'::geometry);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 8d8161c29..5f8ff612c 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -479,3 +479,4 @@ ERROR:  Geometry contains invalid coordinates
 #5639|fullywithin7|t
 #5597|{"type": "Feature", "geometry": null, "properties": {}}
 #5677|POLYGON((0 0,0 10,20 22,20 30,30 30,30 20,22 20,10 0,0 0))
+#5686|0
Summary of changes:
 postgis/lwgeom_ogc.c          | 4 ++--
 regress/core/tickets.sql      | 2 ++
 regress/core/tickets_expected | 1 +
 3 files changed, 5 insertions(+), 2 deletions(-)
hooks/post-receive
