[PostGIS] #5687: PostgreSQL 17 regression failures with spgist indexes
PostGIS trac at osgeo.org
Tue Mar 5 15:45:38 PST 2024
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by robe):
 Okay I think I pinpointed.  Seems ot have started going south after this
 patch
 https://git.postgresql.org/gitweb/?p=postgresql.git;a=commit;h=2af07e2f749a9208ca1ed84fa1d8fe0e75833288
 Commit 2af07e2f749a9208ca1ed84fa1d8fe0e75833288 by jdavis
 Fix search_path to a safe value during maintenance operations.
 While executing maintenance operations (ANALYZE, CLUSTER, REFRESH
 MATERIALIZED VIEW, REINDEX, or VACUUM), set search_path to
 'pg_catalog, pg_temp' to prevent inconsistent behavior.
 Functions that are used for functional indexes, in index expressions,
 or in materialized views and depend on a different search path must be
 declared with CREATE FUNCTION ... SET search_path='...'.
 This change was previously committed as 05e1737351, then reverted in
 commit 2fcc7ee7af because it was too late in the cycle.
 Preparation for the MAINTAIN privilege, which was previously reverted
 due to search_path manipulation hazards.
 Discussion:
 https://postgr.es/m/d4ccaf3658cb3c281ec88c851a09733cd9482f22.camel@j-davis.com
 Discussion: https://postgr.es/m/E1q7j7Y-000z1H-Hr%40gemulon.postgresql.org
 Discussion:
 https://postgr.es/m/e44327179e5c9015c8dda67351c04da552066017.camel%40j-
 davis.com
 Reviewed-by: Greg Stark, Nathan Bossart, Noah Misch
 Which sounds like something they will want to backport, so we might have
 to fix up other branches, before this gets applied to supported PostgreSQL
 versions
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5687#comment:1>
