[SCM] PostGIS branch master updated. 3.4.0rc1-993-g6f25787f3
Thu Mar 7 04:55:01 PST 2024
the project "PostGIS".
       via  6f25787f3dbe14cd140da83c6d790a24c10fbd62 (commit)
       via  a85dbc3f747077953f1671dbd29d8412b6d8987f (commit)
       via  85f49691024e7a878eb06b5e63c55b0913778e6c (commit)
       via  8cbabf69109608d09e37c93b4b6dd0a610a79f0d (commit)
       via  ce5c85b41139a83195e3ebfb6f59e8148aebcc47 (commit)
       via  b9a810b4fc17867521b94ef3d61bb1f5f4f4cfb5 (commit)
       via  dedf5d49d53f463b87df15120545c7e2ea3596fc (commit)
       via  9edfe23f3810628830e6a1dd7c2f87f2e73db0df (commit)
       via  e499c0b1be049a529711f6e7954446203adc31bc (commit)
       via  076924ae307462a60030401efdaac9cfc25ed098 (commit)
       via  1a72eb5c02b4076029b5bf48e24f29c227fbb8ac (commit)
      from  67d2747b894e62d78d29bfebf579b4e54c3f4625 (commit)
revisions in full, below.
commit 6f25787f3dbe14cd140da83c6d790a24c10fbd62
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Tue Feb 20 17:41:41 2024 +0100
    test: rewrite test for CG_StraightSkeleton to compare version. Compare string is not safe in this context.
diff --git a/sfcgal/regress/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
index 5b4fded73..87277db38 100644
--- a/sfcgal/regress/regress_sfcgal.sql
+++ b/sfcgal/regress/regress_sfcgal.sql
@@ -30,7 +30,7 @@ SELECT 'ST_Orientation_2', ST_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,
 SELECT 'ST_MinkowskiSum', ST_AsText(ST_MinkowskiSum('LINESTRING(0 0,4 0)','POLYGON((0 0,1 0,1 1,0 1,0 0))'));
 SELECT 'CG_StraightSkeleton', ST_AsText(CG_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
 SELECT 'CG_StraightSkeletonUseMDistance',
-CASE WHEN postgis_sfcgal_version() >= '1.3.8'
+CASE WHEN string_to_array(postgis_sfcgal_version(), '.')::int[] >= string_to_array('1.3.8', '.')::int[]
 THEN
 	ST_AsText(CG_StraightSkeleton('POLYGON((0 0,1 0,1 1,0 1,0 0))', true))
 ELSE
commit a85dbc3f747077953f1671dbd29d8412b6d8987f
Date:   Tue Feb 20 13:52:27 2024 +0100
    Deprecate ST_StraightSkeleton and update tests accordingly
index aff2f6d58..5b4fded73 100644
@@ -28,8 +28,8 @@ SELECT 'ST_ForceLHR', ST_AsText(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
 SELECT 'ST_Orientation_1', ST_Orientation(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
 SELECT 'ST_Orientation_2', ST_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'ST_StraightSkeleton', ST_AsText(ST_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
-SELECT 'ST_StraightSkeletonUseMDistance',
+SELECT 'CG_StraightSkeleton', ST_AsText(CG_StraightSkeleton('POLYGON((1 1,2 1,2 2,1 2,1 1))'));
+SELECT 'CG_StraightSkeletonUseMDistance',
 THEN
diff --git a/sfcgal/regress/regress_sfcgal_expected b/sfcgal/regress/regress_sfcgal_expected
index 97122bc43..3afb45430 100644
--- a/sfcgal/regress/regress_sfcgal_expected
+++ b/sfcgal/regress/regress_sfcgal_expected
@@ -8,8 +8,8 @@ ST_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
 ST_Orientation_1|-1
 ST_Orientation_2|1
 ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
-ST_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1 2,1.5 1.5))
-ST_StraightSkeletonUseMDistance|MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))
+CG_StraightSkeleton|MULTILINESTRING((1 1,1.5 1.5),(2 1,1.5 1.5),(2 2,1.5 1.5),(1 2,1.5 1.5))
+CG_StraightSkeletonUseMDistance|MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))
 ST_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
 postgis_sfcgal_noop|33
 ST_3DConvexHull|80.9227
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index 94669fb8a..de614c8ba 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -194,11 +194,14 @@ CREATE OR REPLACE FUNCTION CG_StraightSkeleton(geometry, use_m_as_distance boole
        COST 100;
 -- Availability: 2.1.0
+-- Deprecation in 3.1.0
 CREATE OR REPLACE FUNCTION ST_StraightSkeleton(geometry)
-       RETURNS geometry
-       AS 'SELECT @extschema at .CG_StraightSkeleton($1, false)'
-			 LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
-       COST 100;
+RETURNS geometry AS $$
+	SELECT @extschema at ._postgis_deprecate(
+		'ST_StraightSkeleton', 'CG_StraightSkeleton', '3.1.0');
+	SELECT @extschema at .CG_StraightSkeleton($1, false);
+LANGUAGE 'sql' IMMUTABLE SECURITY INVOKER;
 -- Availability: 2.2.0
 CREATE OR REPLACE FUNCTION ST_ApproximateMedialAxis(geometry)
commit 85f49691024e7a878eb06b5e63c55b0913778e6c
Date:   Tue Feb 20 10:35:30 2024 +0100
    Add NEWS entry
diff --git a/NEWS b/NEWS
index bb18e9f5b..ef44b147a 100644
--- a/NEWS
+++ b/NEWS
@@ -30,6 +30,9 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
   - #5659, ST_DFullyWithin behaviour has changed to
            be ST_Contains(ST_Buffer(A, R), B) (Paul Ramsey)
+* Deprecated signatures *
+  - GH-761, ST_StraightSkeleton => CG_StraightSkeleton (Loïc Bartoletti)
 * New Features *
   - #5055, add explicit <> geometry operator to prevent non-unique
@@ -56,8 +59,10 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
             use style.css instead (Chris Mayo)
   - Faster implementation of point-in-poly cached index (Paul Ramsey)
   - Improve performance of ST_GeneratePoints (Paul Ramsey)
-  - #5361, ST_CurveN, ST_NumCurves and consistency in
+  - #5361, ST_CurveN, ST_NumCurves and consistency in
            accessors on curved geometry (Paul Ramsey)
+  - GH-761, postgis_sfcgal: Add an optional parameter to CG_StraightSkeleton
+            (was ST_StraightSkeleton) to use m as a distance in result (Hannes Janetzek, Loïc Bartoletti)
 PostGIS 3.4.0
commit 8cbabf69109608d09e37c93b4b6dd0a610a79f0d
Date:   Tue Feb 20 10:19:53 2024 +0100
    Update doc for ST_StraightSkeleton and add CG_StraightSkeleton
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 13c48fefd..f8f7e696f 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -1258,7 +1258,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
                 Return an approximate medial axis for the areal input based on
                 its straight skeleton. Uses an SFCGAL specific API when built against
                 a capable version (1.2.0+). Otherwise the function is just a wrapper
-                around ST_StraightSkeleton (slower case).
+                around CG_StraightSkeleton (slower case).
             </para>
             <para role="availability" conformance="2.2.0">Availability: 2.2.0</para>
@@ -1293,7 +1293,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refsection>
             <title>See Also</title>
-            <para><xref linkend="ST_StraightSkeleton"/></para>
+            <para><xref linkend="CG_StraightSkeleton"/></para>
         </refsection>
     </refentry>
@@ -1526,7 +1526,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         </refsection>
         <refsection>
-            <para><xref linkend="ST_Extrude" />, <xref linkend="ST_StraightSkeleton" /></para>
+            <para><xref linkend="ST_Extrude" />, <xref linkend="CG_StraightSkeleton" /></para>
         </refsection>
     </refentry>
@@ -1854,6 +1854,72 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         </refsection>
     </refentry>
+    <refentry xml:id="CG_StraightSkeleton">
+        <refnamediv>
+            <refname>CG_StraightSkeleton</refname>
+            <refpurpose>Compute a straight skeleton from a geometry</refpurpose>
+        </refnamediv>
+        <refsynopsisdiv>
+            <funcsynopsis>
+                <funcprototype>
+                    <funcdef>geometry <function>CG_StraightSkeleton</function></funcdef>
+                    <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+                    <paramdef choice="opt"><type>boolean </type> <parameter>use_distance_as_m = false</parameter></paramdef>
+                </funcprototype>
+            </funcsynopsis>
+        </refsynopsisdiv>
+        <refsection>
+            <title>Description</title>
+            <para role="availability" conformance="3.5.0">Availability: 3.5.0</para>
+            <para role="sfcgal_requirement" conformance="1.3.8">Requires SFCGAL >= 1.3.8 for option use_distance_as_m</para>
+            <para>&sfcgal_required;</para>
+            <para>&Z_support;</para>
+            <para>&P_support;</para>
+            <para>&T_support;</para>
+        </refsection>
+        <refsection><title>Examples</title>
+            <programlisting>SELECT CG_StraightSkeleton(ST_GeomFromText('POLYGON (( 190 190, 10 190, 10 10, 190 10, 190 20, 160 30, 60 30, 60 130, 190 140, 190 190 ))'));</programlisting>
+            <programlisting>ST_AsText(CG_StraightSkeleton('POLYGON((0 0,1 0,1 1,0 1,0 0))', true);</programlisting>
+            <screen>MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))</screen>
+            <informaltable>
+                <tgroup cols="2">
+                    <tbody>
+                        <row>
+                            <entry><para><informalfigure>
+                                        <mediaobject>
+                                            <imageobject>
+                                                <imagedata fileref="images/st_straightskeleton01.png"/>
+                                            </imageobject>
+                                            <caption><para>Original polygon</para></caption>
+                                        </mediaobject>
+                                </informalfigure></para>
+                            </entry>
+                                        <mediaobject>
+                                            <imageobject>
+                                                <imagedata fileref="images/st_straightskeleton02.png"/>
+                                            </imageobject>
+                                            <caption><para>Straight Skeleton of polygon</para></caption>
+                                        </mediaobject>
+                            </entry>
+                        </row>
+                    </tbody>
+                </tgroup>
+            </informaltable>
+        </refsection>
+        <refsection>
+            <title>See Also</title>
+            <para><xref linkend="CG_ExtrudeStraightSkeleton" /></para>
+        </refsection>
+    </refentry>
     <refentry xml:id="ST_StraightSkeleton">
         <refnamediv>
commit ce5c85b41139a83195e3ebfb6f59e8148aebcc47
Date:   Tue Feb 20 09:24:28 2024 +0100
    CG_StraightSkeleton: add test for use_m_as_distance
index c409af83f..aff2f6d58 100644
@@ -29,6 +29,14 @@ SELECT 'ST_Orientation_1', ST_Orientation(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,
+SELECT 'ST_StraightSkeletonUseMDistance',
+CASE WHEN postgis_sfcgal_version() >= '1.3.8'
+THEN
+	ST_AsText(CG_StraightSkeleton('POLYGON((0 0,1 0,1 1,0 1,0 0))', true))
+ELSE
+	-- export result directly
+	'MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))'
+END;
 SELECT 'ST_ConstrainedDelaunayTriangles', ST_AsText(ST_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
 SELECT 'postgis_sfcgal_noop', ST_NPoints(postgis_sfcgal_noop(ST_Buffer('POINT(0 0)', 5)));
 SELECT 'ST_3DConvexHull', ST_3DArea(ST_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'))::numeric(10,4);
index 253bf667a..97122bc43 100644
@@ -9,6 +9,7 @@ ST_Orientation_1|-1
 ST_Orientation_2|1
+ST_StraightSkeletonUseMDistance|MULTILINESTRING M ((0 0 0,0.5 0.5 0.5),(1 0 0,0.5 0.5 0.5),(1 1 0,0.5 0.5 0.5),(0 1 0,0.5 0.5 0.5))
commit b9a810b4fc17867521b94ef3d61bb1f5f4f4cfb5
Date:   Tue Feb 20 08:56:47 2024 +0100
    rewrite straight_skeleton function to include m as distance
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 373631a4b..3220e28a6 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -123,7 +123,6 @@ Datum sfcgal_union3D(PG_FUNCTION_ARGS);
 Datum sfcgal_volume(PG_FUNCTION_ARGS);
 Datum sfcgal_extrude(PG_FUNCTION_ARGS);
 Datum sfcgal_straight_skeleton(PG_FUNCTION_ARGS);
-Datum sfcgal_straight_skeleton_distance_in_m(PG_FUNCTION_ARGS);
 Datum sfcgal_approximate_medial_axis(PG_FUNCTION_ARGS);
 Datum sfcgal_is_planar(PG_FUNCTION_ARGS);
 Datum sfcgal_orientation(PG_FUNCTION_ARGS);
@@ -424,6 +423,7 @@ sfcgal_straight_skeleton(PG_FUNCTION_ARGS)
 	sfcgal_geometry_t *geom;
 	sfcgal_geometry_t *result;
 	srid_t srid;
+	bool use_m_as_distance;
 	sfcgal_postgis_init();
@@ -432,7 +432,26 @@ sfcgal_straight_skeleton(PG_FUNCTION_ARGS)
 	geom = POSTGIS2SFCGALGeometry(input);
 	PG_FREE_IF_COPY(input, 0);
-	result = sfcgal_geometry_straight_skeleton(geom);
+	use_m_as_distance = PG_GETARG_BOOL(1);
+	if ( ( POSTGIS_SFCGAL_VERSION < 10308) && use_m_as_distance) {
+		lwpgnotice("The SFCGAL version this PostGIS binary "
+							"was compiled against (%d) doesn't support "
+							"'is_measured' argument in straight_skeleton "
+							"function (1.3.8+ required) "
+						  "fallback to function not using m as distance.",
+							POSTGIS_SFCGAL_VERSION);
+		use_m_as_distance = false;
+  if ( use_m_as_distance )
+		result = sfcgal_geometry_straight_skeleton_distance_in_m(geom);
+  else
+		result = sfcgal_geometry_straight_skeleton(geom);
 	sfcgal_geometry_delete(geom);
 	output = SFCGALGeometry2POSTGIS(result, 0, srid);
@@ -441,39 +460,6 @@ sfcgal_straight_skeleton(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(output);
-PG_FUNCTION_INFO_V1(sfcgal_straight_skeleton_distance_in_m);
-#if POSTGIS_SFCGAL_VERSION < 10308
-	lwpgerror("The SFCGAL version this PostGIS binary "
-	          "was compiled against (%d) doesn't support "
-	          "'sfcgal_straight_skeleton_distance_in_m' "
-	          "function (1.3.8+ required)",
-	          POSTGIS_SFCGAL_VERSION);
-	          PG_RETURN_NULL();
-#else /* POSTGIS_SFCGAL_VERSION >= 10308 */
-	GSERIALIZED *input, *output;
-	sfcgal_geometry_t *geom;
-	sfcgal_geometry_t *result;
-	srid_t srid;
-	sfcgal_postgis_init();
-	input = PG_GETARG_GSERIALIZED_P(0);
-	srid = gserialized_get_srid(input);
-	geom = POSTGIS2SFCGALGeometry(input);
-	PG_FREE_IF_COPY(input, 0);
-	result = sfcgal_geometry_straight_skeleton_distance_in_m(geom);
-	sfcgal_geometry_delete(geom);
-	output = SFCGALGeometry2POSTGIS(result, 0, srid);
-	sfcgal_geometry_delete(result);
-	PG_RETURN_POINTER(output);
-#endif
 PG_FUNCTION_INFO_V1(sfcgal_approximate_medial_axis);
 Datum
index b1faa75ed..94669fb8a 100644
@@ -186,18 +186,18 @@ CREATE OR REPLACE FUNCTION ST_MinkowskiSum(geometry, geometry)
        LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
        COST 100;
--- Availability: 3.4.0
-CREATE OR REPLACE FUNCTION ST_StraightSkeletonDistanceInM(geometry)
+-- Availability: 3.5.0
+CREATE OR REPLACE FUNCTION CG_StraightSkeleton(geometry, use_m_as_distance boolean DEFAULT false)
        RETURNS geometry
-       AS 'MODULE_PATHNAME','sfcgal_straight_skeleton_distance_in_m'
+       AS 'MODULE_PATHNAME','sfcgal_straight_skeleton'
        COST 100;
        RETURNS geometry
-       AS 'MODULE_PATHNAME','sfcgal_straight_skeleton'
-       LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+       AS 'SELECT @extschema at .CG_StraightSkeleton($1, false)'
+			 LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
        COST 100;
commit dedf5d49d53f463b87df15120545c7e2ea3596fc
Author: Hannes Janetzek <hannes.janetzek at gmail.com>
Date:   Fri Apr 21 08:27:23 2023 +0200
    cleanup
diff --git a/liblwgeom/lwgeom_sfcgal.c b/liblwgeom/lwgeom_sfcgal.c
index 3961598d3..3310b681d 100644
--- a/liblwgeom/lwgeom_sfcgal.c
+++ b/liblwgeom/lwgeom_sfcgal.c
@@ -133,13 +133,17 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 	POINT4D point;
 	uint32_t i, npoints;
 	POINTARRAY *pa = NULL;
+	int is_3d;
+	int is_measured = 0;
 	assert(geom);
-	int is_3d = sfcgal_geometry_is_3d(geom);
+	is_3d = sfcgal_geometry_is_3d(geom);
 #if POSTGIS_SFCGAL_VERSION >= 10308
-	int is_measured = sfcgal_geometry_is_measured(geom);
+	is_measured = sfcgal_geometry_is_measured(geom);
 #endif
 	switch (sfcgal_geometry_type_id(geom))
 	case SFCGAL_TYPE_POINT:
@@ -152,10 +156,10 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 			point.z = sfcgal_point_z(geom);
 		else if (want3d)
 			point.z = 0.0;
-#if POSTGIS_SFCGAL_VERSION >= 10308
 		if (is_measured)
 			point.m = sfcgal_point_m(geom);
-#endif
 		ptarray_set_point4d(pa, 0, &point);
 	break;
@@ -175,10 +179,10 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 				point.z = sfcgal_point_z(pt);
 			else if (want3d)
 				point.z = 0.0;
 			if (is_measured)
 				point.m = sfcgal_point_m(pt);
-#endif
 			ptarray_set_point4d(pa, i, &point);
@@ -198,10 +202,10 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 			else if (want3d)
 				point.z = 0.0;
 			if (is_measured)
-#endif
commit 9edfe23f3810628830e6a1dd7c2f87f2e73db0df
Date:   Fri Apr 21 07:53:45 2023 +0200
    add checks for sfcgal version
index a9fb5409c..3961598d3 100644
@@ -137,8 +137,9 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 	assert(geom);
+#if POSTGIS_SFCGAL_VERSION >= 10308
+#endif
@@ -151,9 +152,10 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 		else if (want3d)
 			point.z = 0.0;
 		if (is_measured)
+#endif
 	break;
@@ -173,9 +175,10 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 			else if (want3d)
 				point.z = 0.0;
-                        if (is_measured)
-                                 point.m = sfcgal_point_m(pt);
+			if (is_measured)
+				point.m = sfcgal_point_m(pt);
+#endif
@@ -195,9 +198,10 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 			else if (want3d)
 				point.z = 0.0;
 			if (is_measured)
+#endif
index a315d8eca..373631a4b 100644
@@ -123,6 +123,7 @@ Datum sfcgal_union3D(PG_FUNCTION_ARGS);
+Datum sfcgal_straight_skeleton_distance_in_m(PG_FUNCTION_ARGS);
@@ -443,6 +444,14 @@ sfcgal_straight_skeleton(PG_FUNCTION_ARGS)
+#if POSTGIS_SFCGAL_VERSION < 10308
+	lwpgerror("The SFCGAL version this PostGIS binary "
+	          "'sfcgal_straight_skeleton_distance_in_m' "
+	          "function (1.3.8+ required)",
+	          PG_RETURN_NULL();
+#else /* POSTGIS_SFCGAL_VERSION >= 10308 */
@@ -462,6 +471,7 @@ Datum sfcgal_straight_skeleton_distance_in_m(PG_FUNCTION_ARGS)
+#endif
commit e499c0b1be049a529711f6e7954446203adc31bc
Date:   Thu Apr 20 15:49:34 2023 +0200
    fixup
index 0f0694961..a315d8eca 100644
@@ -423,19 +423,15 @@ sfcgal_straight_skeleton(PG_FUNCTION_ARGS)
 	srid_t srid;
-	int distance_in_m;
-	distance_in_m = PG_GETARG_BOOL(1);
-	if (distance_in_m)
-	else
commit 076924ae307462a60030401efdaac9cfc25ed098
Date:   Thu Apr 20 13:25:28 2023 +0200
    add ST_StraightSkeletonDistanceInM
index f9acd1016..0f0694961 100644
@@ -418,6 +418,34 @@ sfcgal_force_lhr(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(sfcgal_straight_skeleton);
 Datum
+	GSERIALIZED *input, *output;
+	sfcgal_geometry_t *geom;
+	sfcgal_geometry_t *result;
+	srid_t srid;
+	int distance_in_m;
+	sfcgal_postgis_init();
+	input = PG_GETARG_GSERIALIZED_P(0);
+	distance_in_m = PG_GETARG_BOOL(1);
+	srid = gserialized_get_srid(input);
+	geom = POSTGIS2SFCGALGeometry(input);
+	PG_FREE_IF_COPY(input, 0);
+	if (distance_in_m)
+	else
+	sfcgal_geometry_delete(geom);
+	output = SFCGALGeometry2POSTGIS(result, 0, srid);
+	sfcgal_geometry_delete(result);
+	PG_RETURN_POINTER(output);
+PG_FUNCTION_INFO_V1(sfcgal_straight_skeleton_distance_in_m);
@@ -431,7 +459,7 @@ sfcgal_straight_skeleton(PG_FUNCTION_ARGS)
index 7f1006f98..b1faa75ed 100644
@@ -186,6 +186,13 @@ CREATE OR REPLACE FUNCTION ST_MinkowskiSum(geometry, geometry)
        COST 100;
+-- Availability: 3.4.0
+CREATE OR REPLACE FUNCTION ST_StraightSkeletonDistanceInM(geometry)
+       RETURNS geometry
+       AS 'MODULE_PATHNAME','sfcgal_straight_skeleton_distance_in_m'
+       LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+       COST 100;
        RETURNS geometry
commit 1a72eb5c02b4076029b5bf48e24f29c227fbb8ac
Date:   Sun Mar 22 13:34:57 2020 +0100
    Add m component from sfcgal geometries
index 0eb581f43..a9fb5409c 100644
@@ -136,18 +136,23 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 	assert(geom);
+	int is_3d = sfcgal_geometry_is_3d(geom);
+	int is_measured = sfcgal_geometry_is_measured(geom);
-		pa = ptarray_construct(want3d, 0, 1);
+		pa = ptarray_construct(want3d, is_measured, 1);
 		point.x = sfcgal_point_x(geom);
 		point.y = sfcgal_point_y(geom);
-		if (sfcgal_geometry_is_3d(geom))
+		if (is_3d)
 		else if (want3d)
 			point.z = 0.0;
+		if (is_measured)
+			point.m = sfcgal_point_m(geom);
@@ -156,7 +161,7 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 	case SFCGAL_TYPE_LINESTRING:
 		npoints = sfcgal_linestring_num_points(geom);
-		pa = ptarray_construct(want3d, 0, npoints);
+		pa = ptarray_construct(want3d, is_measured, npoints);
 		for (i = 0; i < npoints; i++)
@@ -164,10 +169,12 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 			point.x = sfcgal_point_x(pt);
 			point.y = sfcgal_point_y(pt);
+			if (is_3d)
 			else if (want3d)
 				point.z = 0.0;
+                        if (is_measured)
@@ -176,7 +183,7 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
 	case SFCGAL_TYPE_TRIANGLE:
-		pa = ptarray_construct(want3d, 0, 4);
+		pa = ptarray_construct(want3d, is_measured, 4);
 		for (i = 0; i < 4; i++)
@@ -184,10 +191,12 @@ ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int want3d)
+			if (is_3d)
 			else if (want3d)
 				point.z = 0.0;
+			if (is_measured)
Summary of changes:
 NEWS                                   |  7 +++-
 doc/reference_sfcgal.xml               | 72 ++++++++++++++++++++++++++++++++--
 liblwgeom/lwgeom_sfcgal.c              | 29 +++++++++++---
 sfcgal/lwgeom_sfcgal.c                 | 22 ++++++++++-
 sfcgal/regress/regress_sfcgal.sql      | 10 ++++-
 sfcgal/regress/regress_sfcgal_expected |  3 +-
 sfcgal/sfcgal.sql.in                   | 14 ++++++-
 7 files changed, 142 insertions(+), 15 deletions(-)
hooks/post-receive
