[PostGIS] #5689: Set PostGIS windows bundle environment for service rather than machine.
PostGIS trac at osgeo.org
Thu Mar 7 14:02:29 PST 2024
  Reporter:  slefranc     |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS Packaging
 Component:  install      |    Version:  3.3.x
Resolution:               |   Keywords:  windows
Description changed by slefranc:
Old description:
> The PostGIS Windows bundle (postgis-bundle-pg15x64-setup-3.3.2-2.exe)
> asks the user if they want to set environment variables during
> installation.
> The environment is set at the machine level. This works for PostGIS
> itself, but can cause conflicts with other geospatial software. In our
> case, the GDAL variables (GDAL_DATA and PROJ_LIB) were conflicting with
> R's own GDAL libraries.
> I was able to set the environment at the service level instead:
> path:
> HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\postgresql-x64-15
> REG_MULTI_SZ:
>       GDAL_DATA=C:\Program Files\PostgreSQL\15\gdal-data
>       POSTGIS_ENABLE_OUTDB_RASTERS=1
>       POSTGIS_GDAL_ENABLED_DRIVERS=GTiff PNG JPEG GIF XYZ DTED USGSDEM
> AAIGrid
>       PROJ_LIB=C:\Program
> Files\PostgreSQL\15\share\contrib\postgis-3.3\proj
> This has worked so far in our teaching lab setup, but I haven't done
> thorough testing of all PostGIS functions.
> Would it be possible to have the installer set the environment like this
> instead of globally, assuming it passes broader tests?
New description:
 The PostGIS Windows bundle (postgis-bundle-pg15x64-setup-3.3.2-2.exe) asks
 the user if they want to set environment variables during installation.
 I was able to set the environment at the service level instead using the
 registry:
 path:
 REG_MULTI_SZ:
 AAIGrid
       PROJ_LIB=C:\Program
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5689#comment:1>
