[SCM] PostGIS branch master updated. 3.4.0rc1-995-g6a6d7dadd
Fri Mar 8 01:46:05 PST 2024
the project "PostGIS".
       via  6a6d7dadd98e79daa4abec3ae2d8dfc3f58618f9 (commit)
      from  865bfe8c67f877bd2a442804ebb9fd10dc4ae4dd (commit)
revisions in full, below.
commit 6a6d7dadd98e79daa4abec3ae2d8dfc3f58618f9
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Mar 4 19:13:47 2024 +0100
    Use GEOS-3.7+ GEOSDistanceIndexed to find existing edges
    Closes #3587 in master branch (3.5.0dev)
diff --git a/NEWS b/NEWS
index ef44b147a..4a9b8e8b0 100644
--- a/NEWS
+++ b/NEWS
@@ -50,6 +50,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
 * Enhancements *
+  - #3587, faster load of big lines in topologies (Sandro Santilli)
   - #5670, faster ST_CreateTopoGeo (Sandro Santilli)
   - #5531, documentation format upgraded to DocBook 5 (Sandro Santilli)
   - #5543, allow building without documentation (Sandro Santilli)
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 630cace9f..b84f7ed63 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -5669,21 +5669,32 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     line->points->npoints, numedges);
   if ( numedges )
+    /* TODO: compute earlier for reuse later ? */
+    GEOSGeometry *noded_g = LWGEOM2GEOS(noded, 0);
     /* collect those whose distance from us is < tol */
     nearbycount += numedges;
     nearby = lwalloc(numedges * sizeof(LWGEOM *));
     for (i=0; i<numedges; ++i)
       LW_ON_INTERRUPT(return NULL);
       LWT_ISO_EDGE *e = &(edges[i]);
       LWGEOM *g = lwline_as_lwgeom(e->geom);
-      LWDEBUGF(2, "Computing distance from edge %d having %d points", i, e->geom->points->npoints);
-      double dist = lwgeom_mindistance2d(g, noded);
-      /* must be closer than tolerated, unless distance is zero */
+      GEOSGeometry *edge_g = LWGEOM2GEOS(g, 0);
+      LWDEBUGF(2, "Computing distance from edge %d with %d points", i, e->geom->points->npoints);
+      double dist;
+      if ( 0 == GEOSDistanceIndexed(edge_g, noded_g, &dist) ) {
+        GEOSGeom_destroy(edge_g);
+        GEOSGeom_destroy(noded_g);
+        lwgeom_free(noded);
+        lwerror("GEOSDistanceIndexed error: %s", lwgeom_geos_errmsg);
+        return NULL;
       if ( dist && dist >= tol ) continue;
       nearby[nearbyindex++] = g;
     LWDEBUGF(1, "Found %d edges closer than tolerance (%g)", nearbyindex, tol);
   int nearbyedgecount = nearbyindex;
Summary of changes:
 NEWS                         |  1 +
 liblwgeom/topo/lwgeom_topo.c | 21 ++++++++++++++++-----
 2 files changed, 17 insertions(+), 5 deletions(-)
hooks/post-receive
