[PostGIS] #5666: Build reproducibility: timestamps in extension upgrade SQL scripts
PostGIS trac at osgeo.org
Sun Mar 10 09:10:36 PDT 2024
  Reporter:  James Addison  |      Owner:  strk
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:
 Component:  build          |    Version:  3.4.x
Resolution:                 |   Keywords:
Changes (by James Addison):
 * owner:  pramsey => strk
 * component:  postgis => build
Comment:
 Apologies for the edit noise; this appears to be a build-related issue, so
 I'm reassigning the component (and that auto-adjusts the owner, by the
 looks of it).
 I'll also see whether I can propose a fix for this using gitea.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5666#comment:2>
