[SCM] PostGIS branch master updated. 3.4.0rc1-1003-gd0193e2bb
Sun Mar 10 18:02:18 PDT 2024
the project "PostGIS".
       via  d0193e2bbd67f725d27e6bab7123bac71dfd576f (commit)
       via  cbaa183be5ad87d4ed96d947a0e03a063e889e17 (commit)
      from  dd0ff5257f8fa4a5a90151ef835910aec3fe8ed8 (commit)
revisions in full, below.
commit d0193e2bbd67f725d27e6bab7123bac71dfd576f
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Mar 10 21:00:27 2024 -0400
    FIX for PostgreSQL 17 regression failure on spgist
    For script installs, don't rely on search_path
    to determine schema postgis is installed.
    Closes #5687 for PostGIS 3.5.0
diff --git a/NEWS b/NEWS
index 4a9b8e8b0..a828e3583 100644
--- a/NEWS
+++ b/NEWS
@@ -47,6 +47,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.5.0+ is needed.
   - GH-760, postgis_sfcgal: CG_Intersection, CG_3DIntersects, CG_Intersects,
             CG_Difference, CG_Union (and aggregate), CG_Triangulate, CG_Area,
             CG_3DDistance, CG_Distance (Loïc Bartoletti)
+  - #5687, Don't rely on search_path to determine postgis schema
+           Fix for PG17 security change (Regina Obe)
 * Enhancements *
diff --git a/libpgcommon/lwgeom_pg.c b/libpgcommon/lwgeom_pg.c
index 4a5a99d4f..331f8cb78 100644
--- a/libpgcommon/lwgeom_pg.c
+++ b/libpgcommon/lwgeom_pg.c
@@ -100,23 +100,52 @@ postgis_get_extension_schema(Oid ext_oid)
 static Oid
 postgis_get_full_version_schema()
-	const char* proname = "postgis_full_version";
+	const char* query =  "SELECT pronamespace "
+		" FROM pg_catalog.pg_proc "
+		" WHERE proname = 'postgis_full_version'";
+	int spi_result;
+	Oid funcNameSpaceOid;
-	#if POSTGIS_PGSQL_VERSION < 160
-	List* names = stringToQualifiedNameList(proname);
-	#else
-	List* names = stringToQualifiedNameList(proname, NULL);
-	#endif
-	#if POSTGIS_PGSQL_VERSION < 140
-	FuncCandidateList clist = FuncnameGetCandidates(names, -1, NIL, false, false, false);
-	#else
-	FuncCandidateList clist = FuncnameGetCandidates(names, -1, NIL, false, false, false, false);
-	#endif
-	if (!clist)
+	if (SPI_OK_CONNECT != SPI_connect())
+		elog(ERROR, "%s: could not connect to SPI manager", __func__);
 		return InvalidOid;
-	return get_func_namespace(clist->oid);
+	/* Execute the query, noting the readonly status of this SQL */
+	spi_result = SPI_execute(query, TRUE, 0);
+	if (spi_result != SPI_OK_SELECT || SPI_tuptable == NULL){
+		elog(ERROR, "%s: error executing query %d", __func__, spi_result);
+		SPI_finish();
+		return InvalidOid;
+	/* Read back the OID of the function namespace, only if one result returned
+	  If more than one, then this install is f..cked.
+		If 0 then postgis is not installed at all */
+	if (SPI_processed == 1)
+		TupleDesc tupdesc;
+		SPITupleTable *tuptable = SPI_tuptable;
+		HeapTuple tuple;
+		tupdesc = SPI_tuptable->tupdesc;
+		tuptable = SPI_tuptable;
+		tuple = tuptable->vals[0];
+		funcNameSpaceOid = atoi(SPI_getvalue(tuple, tupdesc, 1));
+		if (SPI_tuptable) SPI_freetuptable(tuptable);
+		SPI_finish();
+	else
+		elog(ERROR, "Cannot determine install schema of postgis_full_version function.");
+		SPI_finish();
+	return funcNameSpaceOid;
commit cbaa183be5ad87d4ed96d947a0e03a063e889e17
Date:   Sun Mar 10 13:38:25 2024 -0400
    Get rid of rc paths and add missing released paths
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 4b58b767d..370e8075b 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -91,6 +91,4 @@ UPGRADEABLE_VERSIONS = \
 	3.3.3 \
 	3.3.4 \
 	3.4.0 \
-	3.4.0rc1 \
-	3.4.0rc2 \
-	3.4.0dev
+	3.4.1dev
Summary of changes:
 NEWS                               |  2 ++
 extensions/upgradeable_versions.mk |  4 +--
 libpgcommon/lwgeom_pg.c            | 59 ++++++++++++++++++++++++++++----------
 3 files changed, 47 insertions(+), 18 deletions(-)
hooks/post-receive
