[PostGIS] #5694: berrie64 always failing on interrupt tests
PostGIS trac at osgeo.org
Mon Mar 11 16:58:30 PDT 2024
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.5.0
Component:  postgis  |    Version:  3.4.x
 Keywords:           |
 berrie64 has been failing consistently on interrupt tests for past couple
 of runs
 https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/5759/label=berrie64/consoleFull
 00:01:44 PostgreSQL 17devel on aarch64-unknown-linux-gnu, compiled by gcc
 (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
 00:01:44   Postgis 3.5.0dev - (4057a91) - 2024-03-11 02:12:26
 00:01:44   scripts 3.5.0dev 4057a91
 00:01:44   GEOS: 3.13.0dev-CAPI-1.18.0
 00:01:44   PROJ: 7.2.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/home/jenkins/.local/share/proj
 DATABASE_PATH=/usr/share/proj/proj.db
 00:01:44   Most PostGIS functions locked into view usage
 00:05:47  regress/core/interrupt_relate .. failed (diff expected obtained:
 /tmp/pgis_reg/test_123_diff)
 00:06:16
 00:06:16 --- ./core/interrupt_relate_expected   2024-03-10
 20:11:13.578793975 -0600
 00:06:16 +++ /tmp/pgis_reg/test_123_out 2024-03-10 22:06:16.037211437
 -0600
 00:06:16 @@ -1,5 +1,5 @@
 00:06:16  ERROR:  canceling statement due to statement timeout
 00:06:16 -contains interrupted on time
 00:06:16 +contains interrupted late: 00:00:14.510019 (00:00:02.01476
 tolerated)
 00:06:16  covers interrupted on time
 00:06:16
 Not sure if this signals some sort of issue with PG17 or if I should just
 turn the interrupt tests off, as they are usually false negatives.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5694>
