[SCM] PostGIS branch master updated. 3.4.0rc1-1010-g3dcfcce5b
Tue Mar 12 09:24:13 PDT 2024
the project "PostGIS".
       via  3dcfcce5b3f5c6a3db4557442e5400564a31dbeb (commit)
      from  4b1f8717530450a4b7a99cf1b701e2642c7e3e92 (commit)
revisions in full, below.
commit 3dcfcce5b3f5c6a3db4557442e5400564a31dbeb
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Mar 12 12:24:08 2024 -0400
    Update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 1bba309e8..bf9622755 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2024-01-26 18:34+0000\n"
+"POT-Creation-Date: 2024-03-12 16:22+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -9667,7 +9667,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 "the <parameter>geom</parameter> field <varname>LINESTRING</varname>s "
-"represent the segments of the supplied geometry."
+"represent the linear segments of the supplied geometry, while the "
+"<varname>CIRCULARSTRING</varname>s represent the arc segments."
 msgstr ""
 #. Tag: para
@@ -10010,6 +10011,38 @@ msgid ""
 "linkend=\"ST_NumInteriorRings\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Return the number of component curves in a CompoundCurve."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Return the number of component curves in a CompoundCurve, zero for an empty "
+"CompoundCurve, or NULL for a non-CompoundCurve input."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_Dump\"/>, <xref linkend=\"ST_ExteriorRing\"/>, <xref "
+"linkend=\"ST_NumInteriorRings\"/>, <xref linkend=\"ST_NumGeometries\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Returns the Nth component curve geometry of a CompoundCurve."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns the Nth component curve geometry of a CompoundCurve. The index "
+"starts at 1. Returns NULL if the geometry is not a CompoundCurve or the "
+"index is out of range."
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -31245,30 +31278,6 @@ msgid ""
 "supported by these functions are TINS and Polyhedral Surfaces."
 msgstr ""
-#. Tag: refpurpose
-#, no-c-format
-msgid "Computes area of 3D surface geometries. Will return 0 for solids."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 8.1, 10.5"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Note: By default a PolyhedralSurface built from WKT is a surface geometry, "
-"not solid. It therefore has surface area. Once converted to a solid, no area."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>, <xref "
-"linkend=\"ST_Area\"/>"
-msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Force LHR orientation"
@@ -31311,6 +31320,56 @@ msgid ""
 "counterclockwise oriented and 1 if the polygon is clockwise oriented."
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Calculates the area of a geometry"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Calculates the area of a geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Performed by the SFCGAL module"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"NOTE: this function returns a double precision value representing the area."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_Area\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes area of 3D surface geometries. Will return 0 for solids."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "&sqlmm_compliant; SQL-MM IEC 13249-3: 8.1, 10.5"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Note: By default a PolyhedralSurface built from WKT is a surface geometry, "
+"not solid. It therefore has surface area. Once converted to a solid, no area."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_MakeSolid\"/>, <xref linkend=\"ST_IsSolid\"/>, <xref "
+"linkend=\"ST_Area\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -31342,6 +31401,147 @@ msgstr ""
 msgid "SFCGAL Processing and Relationship Functions"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes the intersection of two geometries"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Computes the intersection of two geometries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "NOTE: this function returns a geometry representing the intersection."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_Intersection\"/>"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_3DIntersects\"/>, <xref linkend=\"ST_Intersects\"/>, "
+"<xref linkend=\"ST_Disjoint\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Tests if two 3D geometries intersect"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Tests if two 3D geometries intersect. 3D geometries intersect if they have "
+"any point in common in the three-dimensional space."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes the geometric difference between two geometries"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Computes the geometric difference between two geometries. The resulting "
+"geometry is a set of points that are present in geomA but not in geomB."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "NOTE: this function returns a geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_Difference\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Perform 3D difference"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Returns that part of geom1 that is not part of geom2."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"3D images were generated using PostGIS <xref linkend=\"ST_AsX3D\"/> and "
+"rendering in HTML using <link xlink:href=\"http://www.x3dom.org\">X3Dom HTML "
+"Javascript rendering library</link>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Original 3D geometries overlaid. geom2 is the part that will be removed."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "What's left after removing geom2"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_AsX3D\"/>, <xref linkend=\"ST_3DIntersection\"/> <xref "
+"linkend=\"ST_3DUnion\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes the minimum distance between two geometries"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Computes the minimum distance between two geometries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"NOTE: this function returns a double precision value representing the "
+"distance."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_Distance\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes the minimum 3D distance between two geometries"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Computes the minimum 3D distance between two geometries."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"NOTE: this function returns a double precision value representing the 3D "
+"distance."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_3DDistance\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Computes the 3D convex hull of a geometry."
@@ -31367,14 +31567,6 @@ msgstr ""
 msgid "Return a geometry that is the shared portion between geom1 and geom2."
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"3D images were generated using PostGIS <xref linkend=\"ST_AsX3D\"/> and "
-"rendering in HTML using <link xlink:href=\"http://www.x3dom.org\">X3Dom HTML "
-"Javascript rendering library</link>."
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Original 3D geometries overlaid. geom2 is shown semi-transparent"
@@ -31404,30 +31596,17 @@ msgstr ""
 #. Tag: refpurpose
 #, no-c-format
-msgid "Perform 3D difference"
+msgid "Computes the union of two geometries"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Returns that part of geom1 that is not part of geom2."
+msgid "Computes the union of two geometries."
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ""
-"Original 3D geometries overlaid. geom2 is the part that will be removed."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "What's left after removing geom2"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-", <xref linkend=\"ST_AsX3D\"/>, <xref linkend=\"ST_3DIntersection\"/> <xref "
-"linkend=\"ST_3DUnion\"/>"
+msgid "NOTE: this function returns a geometry representing the union."
 msgstr ""
 #. Tag: refpurpose
@@ -31616,7 +31795,7 @@ msgid ""
 "Return an approximate medial axis for the areal input based on its straight "
 "skeleton. Uses an SFCGAL specific API when built against a capable version "
 "(1.2.0+). Otherwise the function is just a wrapper around "
-"ST_StraightSkeleton (slower case)."
+"CG_StraightSkeleton (slower case)."
 msgstr ""
 #. Tag: para
@@ -31711,7 +31890,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ", <xref linkend=\"ST_StraightSkeleton\"/>"
+msgid ", <xref linkend=\"CG_StraightSkeleton\"/>"
 msgstr ""
 #. Tag: para
@@ -31893,6 +32072,11 @@ msgstr ""
 msgid "Compute a straight skeleton from a geometry"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Requires SFCGAL >= 1.3.8 for option use_distance_as_m"
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Straight Skeleton of polygon"
@@ -31946,6 +32130,22 @@ msgid ""
 "linkend=\"ST_TriangulatePolygon\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Triangulates a polygonal geometry"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Triangulates a polygonal geometry."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"NOTE: this function returns a geometry representing the triangulated result."
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
Summary of changes:
 doc/po/templates/postgis-manual.pot | 284 ++++++++++++++++++++++++++++++------
 1 file changed, 242 insertions(+), 42 deletions(-)
hooks/post-receive
