[SCM] PostGIS branch master updated. 3.4.0rc1-1014-g2c4abb3f2
Wed Mar 13 15:51:01 PDT 2024
the project "PostGIS".
       via  2c4abb3f268b1e806e59337bf737fbcc04d9b31e (commit)
      from  1284f168d7159c8585b46f9bdfd54c63927f8c9e (commit)
revisions in full, below.
commit 2c4abb3f268b1e806e59337bf737fbcc04d9b31e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Mar 13 15:50:50 2024 -0700
    Clean up recttree a little bit
diff --git a/liblwgeom/lwtree.c b/liblwgeom/lwtree.c
index 481b329f6..19a6bd41c 100644
--- a/liblwgeom/lwtree.c
+++ b/liblwgeom/lwtree.c
@@ -82,7 +82,7 @@ rect_tree_free(RECT_NODE *node)
 static int
-rect_leaf_node_intersects(RECT_NODE_LEAF *n1, RECT_NODE_LEAF *n2)
+rect_leaf_node_intersects(const RECT_NODE_LEAF *n1, const RECT_NODE_LEAF *n2)
 	const POINT2D *p1, *p2, *p3, *q1, *q2, *q3;
 	DISTPTS dl;
@@ -196,7 +196,7 @@ rect_leaf_node_intersects(RECT_NODE_LEAF *n1, RECT_NODE_LEAF *n2)
 * Returns 1 if segment is to the right of point.
 static inline int
-rect_leaf_node_segment_side(RECT_NODE_LEAF *node, const POINT2D *q, int *on_boundary)
+rect_leaf_node_segment_side(const RECT_NODE_LEAF *node, const POINT2D *q, int *on_boundary)
 	const POINT2D *p1, *p2, *p3;
 	switch (node->seg_type)
@@ -311,7 +311,7 @@ rect_leaf_node_segment_side(RECT_NODE_LEAF *node, const POINT2D *q, int *on_boun
 * be on both sides, and will have a zero return sum.
 static int
-rect_tree_ring_contains_point(RECT_NODE *node, const POINT2D *pt, int *on_boundary)
+rect_tree_ring_contains_point(const RECT_NODE *node, const POINT2D *pt, int *on_boundary)
 	/* Only test nodes that straddle our stabline vertically */
 	/* and might be to the right horizontally */
@@ -341,7 +341,7 @@ rect_tree_ring_contains_point(RECT_NODE *node, const POINT2D *pt, int *on_bounda
 * (multiply contained by interior rings?)
 static int
-rect_tree_area_contains_point(RECT_NODE *node, const POINT2D *pt)
+rect_tree_area_contains_point(const RECT_NODE *node, const POINT2D *pt)
 	/* Can't do anything with a leaf node, makes no sense */
 	if (rect_node_is_leaf(node))
@@ -381,7 +381,7 @@ rect_tree_area_contains_point(RECT_NODE *node, const POINT2D *pt)
 * Simple containment test for node/point inputs
 static int
-rect_node_bounds_point(RECT_NODE *node, const POINT2D *pt)
+rect_node_bounds_point(const RECT_NODE *node, const POINT2D *pt)
 	if (pt->y < node->ymin || pt->y > node->ymax ||
 		pt->x < node->xmin || pt->x > node->xmax)
@@ -395,7 +395,7 @@ rect_node_bounds_point(RECT_NODE *node, const POINT2D *pt)
 * and false otherwise.
 int
-rect_tree_contains_point(RECT_NODE *node, const POINT2D *pt)
+rect_tree_contains_point(const RECT_NODE *node, const POINT2D *pt)
 	int i, c;
@@ -762,6 +762,10 @@ rect_tree_from_lwpoly(const LWGEOM *lwgeom)
 			nodes[j++] = node;
+	/* Put the top nodes in a z-order curve for a spatially coherent */
+	/* tree after node merge */
+	qsort(nodes, j, sizeof(RECT_NODE*), rect_node_cmp);
 	tree = rect_nodes_merge(nodes, j);
 	tree->geom_type = lwgeom->type;
 	lwfree(nodes);
@@ -848,7 +852,9 @@ rect_tree_from_lwcollection(const LWGEOM *lwgeom)
 	/* Note: CompoundCurve has edges already spatially organized, no */
 	/* sorting needed */
 	if (lwgeom->type != COMPOUNDTYPE)
@@ -933,7 +939,7 @@ rect_node_to_str(const RECT_NODE *n)
 * that intersect. Prune branches that do not intersect.
 static int
-rect_tree_intersects_tree_recursive(RECT_NODE *n1, RECT_NODE *n2)
+rect_tree_intersects_tree_recursive(const RECT_NODE *n1, const RECT_NODE *n2)
 	int i, j;
 #if POSTGIS_DEBUG_LEVEL >= 4
@@ -987,7 +993,7 @@ rect_tree_intersects_tree_recursive(RECT_NODE *n1, RECT_NODE *n2)
 int
-rect_tree_intersects_tree(RECT_NODE *n1, RECT_NODE *n2)
+rect_tree_intersects_tree(const RECT_NODE *n1, const RECT_NODE *n2)
 	* It is possible for an area to intersect another object
@@ -1014,24 +1020,12 @@ rect_tree_intersects_tree(RECT_NODE *n1, RECT_NODE *n2)
 	return rect_tree_intersects_tree_recursive(n1, n2);
-* For slightly more speed when doing distance comparisons,
-* where we only care if d1 < d2 and not what the actual value
-* of d1 or d2 is, we use the squared distance and avoid the
-* sqrt()
-static inline double
-distance_sq(double x1, double y1, double x2, double y2)
-	double dx = x1-x2;
-	double dy = y1-y2;
-	return dx*dx + dy*dy;
 distance(double x1, double y1, double x2, double y2)
-	return sqrt(distance_sq(x1, y1, x2, y2));
+	double dx = x1-x2;
+	double dy = y1-y2;
+	return sqrt(dx*dx + dy*dy);
@@ -1222,72 +1216,8 @@ rect_leaf_node_distance(const RECT_NODE_LEAF *n1, const RECT_NODE_LEAF *n2, RECT
-static int
-rect_tree_node_sort_cmp(const void *a, const void *b)
-	RECT_NODE *n1 = *(RECT_NODE**)a;
-	RECT_NODE *n2 = *(RECT_NODE**)b;
-	if (n1->d < n2->d) return -1;
-	else if (n1->d > n2->d) return 1;
-	else return 0;
-/* Calculate the center of a node */
-static inline void
-rect_node_to_p2d(const RECT_NODE *n, POINT2D *pt)
-	pt->x = (n->xmin + n->xmax)/2;
-	pt->y = (n->ymin + n->ymax)/2;
-* (If necessary), sort the children of each node in
-* order of their distance from the enter of the other node.
-static void
-rect_tree_node_sort(RECT_NODE *n1, RECT_NODE *n2)
-	int i;
-	RECT_NODE *n;
-	POINT2D c1, c2, c;
-	if (!rect_node_is_leaf(n1) && ! n1->i.sorted)
-		rect_node_to_p2d(n2, &c2);
-		/* Distance of each child from center of other node */
-		for (i = 0; i < n1->i.num_nodes; i++)
-			n = n1->i.nodes[i];
-			rect_node_to_p2d(n, &c);
-			n->d = distance2d_sqr_pt_pt(&c2, &c);
-		/* Sort the children by distance */
-		n1->i.sorted = 1;
-		qsort(n1->i.nodes,
-		         n1->i.num_nodes,
-		         sizeof(RECT_NODE*),
-		         rect_tree_node_sort_cmp);
-	if (!rect_node_is_leaf(n2) && ! n2->i.sorted)
-		rect_node_to_p2d(n1, &c1);
-		for (i = 0; i < n2->i.num_nodes; i++)
-			n = n2->i.nodes[i];
-			n->d = distance2d_sqr_pt_pt(&c1, &c);
-		n2->i.sorted = 1;
-		qsort(n2->i.nodes,
-		         n2->i.num_nodes,
 static double
-rect_tree_distance_tree_recursive(RECT_NODE *n1, RECT_NODE *n2, RECT_TREE_DISTANCE_STATE *state)
+rect_tree_distance_tree_recursive(const RECT_NODE *n1, const RECT_NODE *n2, RECT_TREE_DISTANCE_STATE *state)
 	double min, max;
@@ -1319,7 +1249,6 @@ rect_tree_distance_tree_recursive(RECT_NODE *n1, RECT_NODE *n2, RECT_TREE_DISTAN
 		int i, j;
 		double d_min = FLT_MAX;
-		rect_tree_node_sort(n1, n2);
 		if (rect_node_is_leaf(n1) && !rect_node_is_leaf(n2))
@@ -1351,7 +1280,7 @@ rect_tree_distance_tree_recursive(RECT_NODE *n1, RECT_NODE *n2, RECT_TREE_DISTAN
-double rect_tree_distance_tree(RECT_NODE *n1, RECT_NODE *n2, double threshold)
+double rect_tree_distance_tree(const RECT_NODE *n1, const RECT_NODE *n2, double threshold)
 	double distance;
 	RECT_TREE_DISTANCE_STATE state;
diff --git a/liblwgeom/lwtree.h b/liblwgeom/lwtree.h
index 0aa4cf31d..1167e3c2c 100644
--- a/liblwgeom/lwtree.h
+++ b/liblwgeom/lwtree.h
@@ -95,19 +95,19 @@ RECT_NODE * rect_tree_from_lwgeom(const LWGEOM *geom);
 * Test if two RECT_NODE trees intersect one another.
-int rect_tree_intersects_tree(RECT_NODE *tree1, RECT_NODE *tree2);
+int rect_tree_intersects_tree(const RECT_NODE *tree1, const RECT_NODE *tree2);
 * Return the distance between two RECT_NODE trees.
-double rect_tree_distance_tree(RECT_NODE *n1, RECT_NODE *n2, double threshold);
+double rect_tree_distance_tree(const RECT_NODE *n1, const RECT_NODE *n2, double threshold);
 * Free the rect-tree memory
 void rect_tree_free(RECT_NODE *node);
-int rect_tree_contains_point(RECT_NODE *tree, const POINT2D *pt);
+int rect_tree_contains_point(const RECT_NODE *tree, const POINT2D *pt);
 RECT_NODE * rect_tree_from_ptarray(const POINTARRAY *pa, int geom_type);
 LWGEOM * rect_tree_to_lwgeom(const RECT_NODE *tree);
 char * rect_tree_to_wkt(const RECT_NODE *node);
Summary of changes:
 liblwgeom/lwtree.c | 107 +++++++++--------------------------------------------
 liblwgeom/lwtree.h |   6 +--
 2 files changed, 21 insertions(+), 92 deletions(-)
hooks/post-receive
