[PostGIS] #5687: PostgreSQL 17 regression failures with spgist indexes
PostGIS trac at osgeo.org
Thu Mar 14 07:11:36 PDT 2024
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.4.3
 Component:  postgis  |    Version:  3.4.x
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 3.5.0 => PostGIS 3.4.3
Comment:
 reopening until I backport to at least 3.4.3.  Doesn't look like this
 change has been pushed to other stable branches as I would have expected,
 but we probably should have it for at least 3.4.3.
 I assume there is no harm in pushing to all stable branches since it only
 affects installs not using extension.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5687#comment:11>
