[SCM] PostGIS branch stable-3.4 updated. 3.4.2-13-g3ee973b48
Thu Mar 14 09:16:23 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  3ee973b48ff955378e834ef71769c2d8c2043293 (commit)
       via  ca3073c71272a9a4dd071ef883e3046cd5a46beb (commit)
       via  ce93454fd7fde2b992b70e93a8d6bfd59ccd989e (commit)
      from  af10c4a540b98829394f0a7c9472868c2c7eaac0 (commit)
revisions in full, below.
commit 3ee973b48ff955378e834ef71769c2d8c2043293
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Mar 14 12:15:10 2024 -0400
    Install libcunit1 on gitlab 32-bit
    Also explicitly test liblwgeom cunit as is done on master
    References #5683 for PostGIS 3.4.3
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index bd57ac02d..7498691d5 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -5,7 +5,7 @@
     - apt-get update -qq && apt-get install -y
         bison flex
         postgresql-15 postgresql-server-dev-15
-        build-essential autoconf libtool libcunit1-dev
+        build-essential autoconf libtool libcunit1 libcunit1-dev
         xsltproc docbook-xsl docbook-mathml dblatex
         libproj-dev libgdal-dev libgeos-dev libjson-c-dev
         libprotobuf-c1 libprotobuf-c-dev protobuf-c-compiler
@@ -25,6 +25,8 @@
     - echo "Build dir is ${PWD}"
     - ${SRCDIR}/configure --without-raster CFLAGS="-Wall -fno-omit-frame-pointer -Werror"
     - make
+    - make -C liblwgeom check
+    - su -c 'make' postgres # idempotence test, see #5099
     - RUNTESTFLAGS="-v --dumprestore" make check-regress
     - make install
     - RUNTESTFLAGS="-v --dumprestore" make installcheck
commit ca3073c71272a9a4dd071ef883e3046cd5a46beb
Date:   Thu Mar 14 12:11:51 2024 -0400
    Take out group from docs woodpecker which is not valid for 2+
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 2f3665785..2a823fee6 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -2,7 +2,7 @@
     image: *test_image
     commands:
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
-    group: @GROUP@
+    #group: @GROUP@
     when:
       path:
         include:
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 299d688e4..6c235faa0 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -88,7 +88,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/ja local-check-xml
-    group: localized-check-xml
+    #group: localized-check-xml
     when:
       path:
         include:
@@ -111,7 +111,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/de local-check-xml
     when:
       path:
         include:
@@ -134,7 +134,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/fr local-check-xml
     when:
       path:
         include:
@@ -158,7 +158,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/ja local-html
-    group: localized-html
+    #group: localized-html
     when:
       path:
         include:
@@ -181,7 +181,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/de local-html
     when:
       path:
         include:
@@ -204,7 +204,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/fr local-html
     when:
       path:
         include:
@@ -228,7 +228,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/ja local-cheatsheets
-    group: localized-cheatsheets
+    #group: localized-cheatsheets
     when:
       path:
         include:
@@ -251,7 +251,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
       path:
         include:
@@ -274,7 +274,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
       path:
         include:
@@ -298,7 +298,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
-    group: localized-check-cheatsheets
+    #group: localized-check-cheatsheets
     when:
       path:
         include:
@@ -321,7 +321,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/de local-check-cheatsheets
     when:
       path:
         include:
@@ -344,7 +344,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
     when:
       path:
         include:
@@ -368,7 +368,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/ja local-pdf
-    group: localized-pdf
+    #group: localized-pdf
     when:
       path:
         include:
@@ -391,7 +391,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/de local-pdf
     when:
       path:
         include:
@@ -414,7 +414,7 @@ steps:
     image: *test_image
     commands:
       - make -C build-docs/doc/po/fr local-pdf
     when:
       path:
         include:
commit ce93454fd7fde2b992b70e93a8d6bfd59ccd989e
Date:   Thu Mar 14 12:07:41 2024 -0400
    Fix James Addison credits.  References #5666
diff --git a/NEWS b/NEWS
index 4ef06ae1d..1007714f7 100644
--- a/NEWS
+++ b/NEWS
@@ -16,7 +16,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
  - #5589, ST_3DDistance error for shared first point (Paul Ramsey)
  - #5686, ST_NumInteriorRings and Triangle crash (Paul Ramsey)
  - #5666, Build reproducibility: timestamps
-          in extension upgrade SQL scripts (Jay Addison)
+          in extension upgrade SQL scripts (James Addison)
 PostGIS 3.4.2
diff --git a/doc/introduction.xml b/doc/introduction.xml
index 95acc1af3..afbc8a805 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -274,7 +274,7 @@
 					<member>James Marca</member>
 					<member>Jan Katins</member>
 					<member>Jason Smith</member>
-					<member>Jay Addison</member>
+					<member>James Addison</member>
 					<member>Jeff Adams</member>
 					<member>Jelte Fennema</member>
 					<member>Jim Jones</member>
Summary of changes:
 .gitlab-ci.yml                    |  4 +++-
 .woodpecker/docs-localized.yml.in |  2 +-
 .woodpecker/docs.yml              | 30 +++++++++++++++---------------
 NEWS                              |  2 +-
 doc/introduction.xml              |  2 +-
 5 files changed, 21 insertions(+), 19 deletions(-)
hooks/post-receive
