[SCM] PostGIS branch stable-3.4 updated. 3.4.2-17-g74a65006a
Thu Mar 14 17:03:50 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  74a65006a5fca23ee90a70b33cf9d2feb5ab62bf (commit)
      from  3b6081068e7e996d5740fe4b2b03ed93cdf877d3 (commit)
revisions in full, below.
commit 74a65006a5fca23ee90a70b33cf9d2feb5ab62bf
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Mar 14 19:59:31 2024 -0400
    More fixes for woodie agent
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index 2a823fee6..ece9af87e 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -1,12 +1,10 @@
   @TARGET at -@LANG@:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
-    #group: @GROUP@
+    depends_on: @DEP@
     when:
       path:
         include:
-          # Localized assets
-          - "doc/po/@LANG@/Makefile.in"
           - "doc/po/@LANG@/*.po"
-          - "utils/check_localized_cheatsheets.sh"
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 6c235faa0..a104cfa6a 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -1,32 +1,22 @@
 variables:
   - &test_image 'docker.osgeo.org/postgis/build-test:trisquel3'
+  - common_doc_paths: &common_doc_paths
+      # related config files
+      - ".woodpecker/docs.yml"
+      # Makefiles
+      - "doc/Makefile.in"
+      - "doc/html/images/Makefile.in"
+      # XML sources
+      - "doc/*.xml"
+      # Internationalization Makefiles
+      - "doc/po/Makefile.local"
   - &when_path
       include:
-        # Common docs path
-        # related config files
-        - ".woodpecker/docs.yml"
-        # Makefiles
-        - "doc/Makefile.in"
-        - "doc/html/images/Makefile.in"
-        # XML sources
-        - "doc/*.xml"
-        # Internationalization Makefiles
-        - "doc/po/Makefile.local"
-        # END OF COMMON PATHS
+        - <<: *common_doc_paths
   - &when_path_full
       include:
-        # Makefiles
-        # XML sources
-        - "doc/*.xml"
+        # Any localized assets
         - "doc/po/*/Makefile.in"
         - "doc/po/*/*.po"
@@ -39,44 +29,53 @@ steps:
       - mkdir -p build-docs && cd build-docs
       - ../configure --without-pg --without-protobuf --without-raster
       - make postgis_revision.h
+      - xmllint --version
     when:
       path: *when_path_full
   check-xml:
     image: *test_image
+    pull: true
+    depends_on: prepare
     commands:
       - make -C build-docs/doc check
     when:
       path: *when_path
   build-images:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc images
     when:
-      path: *when_path
+      path: *when_path_full
   build-html:
     image: *test_image
-    group: output
+    pull: true
+    depends_on: check-xml
     commands:
       - make -C build-docs/doc html
     when:
       path: *when_path
   build-cheatsheets:
     image: *test_image
-    group: output
+    pull: true
     commands:
       - make -C build-docs/doc/ cheatsheets
     when:
-      path: *when_path_full
+      path: *when_path
   build-chunked-html:
     image: *test_image
-    group: output
+    pull: true
     commands:
     when:
       path: *when_path
   build-pdf:
     image: *test_image
-    group: output
+    pull: true
+    depends_on: [ build-images, check-xml ]
     commands:
       - make -C build-docs/doc/ pdf
     when:
@@ -86,350 +85,155 @@ steps:
 ### TARGET check-xml
   check-xml-ja:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-xml
-    #group: localized-check-xml
+    depends_on: @DEP@
     when:
       path:
         include:
-          - "doc/po/ja/Makefile.in"
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   check-xml-de:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-xml
+    depends_on: @DEP@
     when:
       path:
         include:
-          - "doc/po/de/Makefile.in"
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   check-xml-fr:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-xml
+    depends_on: @DEP@
     when:
       path:
         include:
-          - "doc/po/fr/Makefile.in"
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
 ### TARGET html
   html-ja:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/ja local-html
-    #group: localized-html
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   html-de:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/de local-html
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   html-fr:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/fr local-html
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
 ### TARGET cheatsheets
   cheatsheets-ja:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/ja local-cheatsheets
-    #group: localized-cheatsheets
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   cheatsheets-de:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/de local-cheatsheets
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   cheatsheets-fr:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/fr local-cheatsheets
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
 ### TARGET check-cheatsheets
   check-cheatsheets-ja:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
-    #group: localized-check-cheatsheets
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   check-cheatsheets-de:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/de local-check-cheatsheets
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   check-cheatsheets-fr:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
 ### TARGET pdf
   pdf-ja:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/ja local-pdf
-    #group: localized-pdf
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/ja/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   pdf-de:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/de local-pdf
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/de/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
   pdf-fr:
     image: *test_image
+    pull: true
     commands:
       - make -C build-docs/doc/po/fr local-pdf
+    depends_on: @DEP@
     when:
       path:
         include:
           - "doc/po/fr/*.po"
-          # Makefiles
-          # XML sources
-          - "doc/*.xml"
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index a6673821a..ba355cecc 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -39,7 +39,7 @@ variables:
     - egrep '(PASS|FAIL|SKIP|INFO|ERROR)' check.log
 clone:
-  clone:
+  git:
     image: woodpeckerci/plugin-git
     depth: 50
@@ -53,7 +53,7 @@ steps:
   build-pg12:
     image: *test-image
-    group: build
+    depends_on: autogen
     environment:
       - PGVER=12
     commands:
@@ -62,7 +62,7 @@ steps:
   build-pg15:
     image: *test-image
-    group: build
     environment:
       - PGVER=15
     commands:
@@ -71,7 +71,7 @@ steps:
   check-pg12:
     image: *test-image
-    group: check
+    depends_on: build-pg12
     environment:
       - PGVER=12
     commands:
@@ -81,7 +81,7 @@ steps:
   check-pg15:
     image: *test-image
-    group: check
+    depends_on: build-pg15
     environment:
       - PGVER=15
     commands:
@@ -91,7 +91,7 @@ steps:
   installcheck-pg12:
     image: *test-image
-    group: installcheck
     environment:
       - PGVER=12
     commands:
@@ -102,7 +102,7 @@ steps:
   installcheck-pg15:
     image: *test-image
     environment:
       - PGVER=15
     commands:
@@ -113,7 +113,7 @@ steps:
   upgradecheck-pg12:
     image: *test-image
-    group: upgradecheck
     environment:
       - PGVER=12
     commands:
@@ -124,7 +124,7 @@ steps:
   upgradecheck-pg15:
     image: *test-image
     environment:
       - PGVER=15
     commands:
Summary of changes:
 .woodpecker/docs-localized.yml.in |   6 +-
 .woodpecker/docs.yml              | 312 +++++++-------------------------------
 .woodpecker/regress.yml           |  18 +--
 3 files changed, 69 insertions(+), 267 deletions(-)
hooks/post-receive
