[PostGIS] #5683: 32bit test fails on ST_SnapToGrid test
PostGIS trac at osgeo.org
Thu Mar 14 17:20:23 PDT 2024
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:  regression
Comment (by robe):
 apologies that thing I thought was a failure
 is expected result and shows on stable-3.4 as well
  Test: test_lwgeom_segmentize2d ...NOTICE:
 /builds/postgis/postgis/liblwgeom/ptarray.c:449 - ptarray_segmentize2d:
 Too many segments required (1.000000e+101)
 But interestingly stable-3.4 32-bit gitlab run is not showing the
 test_grid_in_place error.
 That is passing with flying colors as is the rest of the tests
 https://gitlab.com/postgis/postgis/-/jobs/6398823690#L733
 I thought maybe it was the debian version, but master and stable-3.4 are
 running debian bookworm
 But I do notice the cu_misc.c grid tests change in master which I presume
 pramsey added to exercise
 what is causing the postgresql failures.
 master has an extra test:
         do_grid_test(
                 "LINESTRING(0 0,1 1,1 1,1 1)",
                 "LINESTRING(0 0,1 1)",
                 0.001
 I'm going to add this to 3.4 as well to see if gitlab test32 is still a
 happy camper.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5683#comment:6>
