[PostGIS] #5683: 32bit test fails on ST_SnapToGrid test
PostGIS trac at osgeo.org
Thu Mar 14 19:19:48 PDT 2024
  Reporter:  strk     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.5.0
 Component:  postgis  |    Version:  master
Resolution:           |   Keywords:  regression
Comment (by robe):
 I was reading strk's notice wrong.  I was thinking he was blaming
 pramsey's big fat commit of
 https://trac.osgeo.org/postgis/changeset/dd88d87cfc3b7b7b7f059171fb090ee4b2db8836/git
 No that was the last successful one.
 So whatever the cause of this happened after January 14th (after the
 above).
 Sadly we had a long period of both the test and test32 failing because of
 stupid defined but not used notices,
 /builds/postgis/postgis/liblwgeom/profile.h:5:15: error: 'cpu_time_used'
 defined but not used [-Werror=unused-variable]
     5 | static double cpu_time_used;
 /builds/postgis/postgis/liblwgeom/profile.h:4:28: error: 'end_time'
     4 | static clock_t start_time, end_time;
 /builds/postgis/postgis/liblwgeom/profile.h:4:16: error: 'start_time'
 that evidentally we were blissfully ignoring then followed by another
 storm, of "Regina is sloppy" errors
   272 |       snprintf(errbuf, errbuflen, _("ERROR: column map file
 specifies a DBF field name \"%s\" which is longer than 10 characters"),
 map->dbffieldnames[curmapsize]);
 /builds/postgis/postgis/loader/shpcommon.h:24:19: note: in definition of
 macro '_'
    24 | #define _(String) String
 /builds/postgis/postgis/loader/shpcommon.c:272:52: note: format string is
 defined here
  which we were also blissfully ignoring.
 , then followed by a storm of "What is strk doing with topology?" and why
 is he letting all the bots turn red.
 Until we finally get to @strk commit which fixes the last of those sloppy
 errors
 leaving us with a green on 64-bit test and a red test32
 https://gitlab.com/postgis/postgis/-/jobs/6292825666
 https://gitlab.com/postgis/postgis/-/commit/07a73c0f2c5cb07e33fd64dadd24fac35efdc0a5
 So issue is somewhere after January 14th and on or before February 29th.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5683#comment:9>
