[PostGIS] #5696: Strange regression failure on woodie
PostGIS trac at osgeo.org
Fri Mar 15 18:54:44 PDT 2024
 Reporter:  robe     |      Owner:  strk
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.5.0
Component:  upgrade  |    Version:  master
 Keywords:           |
 I was making changes to address standardizer_data_us extension, which note
 has nothing to do with postgis.  Strangely woodie errors out and only with
 pg15 check.  I'm wondering if this is some-sort of parallel build run
 issue.
 The other runs even the upgrades were fine, it's just check-pg15 that
 failed
 https://woodie.osgeo.org/repos/30/pipeline/1972/10
 Upgrading core
 Died at
 /woodpecker/src/git.osgeo.org/gitea/postgis/postgis/regress/run_test.pl
 line 481.
  failed (Error encountered loading
 /woodpecker/src/git.osgeo.org/gitea/postgis/postgis/build/pg15/regress/00
 -regress-install/share/contrib/postgis/postgis_upgrade.sql:
 /tmp/pgis_reg/regress_log.tmp)
 NOTICE:  schema "public" already exists, skipping
  _postgis_drop_function_by_identity
 (1 row)
 (1 row)
 (1 row)
 psql:/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/build/pg15/regress/00
 -regress-install/share/contrib/postgis/postgis_upgrade.sql:210: NOTICE:
 function st_aslatlontext(geometry) does not exist, skipping
 (1 row)
 (1 row)
 (1 row)
 (1 row)
 (1 row)
 (1 row)
 -regress-install/share/contrib/postgis/postgis_upgrade.sql:260: NOTICE:
 function st_coverageinvalidlocations(geometry,pg_catalog.float8) does not
 exist, skipping
 -regress-install/share/contrib/postgis/postgis_upgrade.sql:305: ERROR:
 could not access file "$libdir/postgis-3.5": No such file or directory
 make[1]: ***
 [/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/regress/runtest.mk:24:
 check-regress] Error 3
 make[1]: Leaving directory
 '/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/build/pg15'
 make: ***
 [/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/regress/runtest.mk:50:
 check-locked-upgrade] Error 2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5696>
