[PostGIS] #5698: XX000: SQL/MM Spatial exception - point not on edge
PostGIS trac at osgeo.org
Thu Mar 21 08:38:53 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 If we create the topology with a tolerance , then it runs with out any
 errors but I try to avoid using tolerances and instead remove tiny areas
 based  on different rules later.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5698#comment:2>
