[PostGIS] #5698: XX000: SQL/MM Spatial exception - point not on edge
PostGIS trac at osgeo.org
Thu Mar 21 21:40:26 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 This seems to be related to adding closed line that already seems to
 covered by existing edges and where there also are two other edges in the
 database.
 Here is a simplified test with the same error.
 Here is the before error code
 SELECT topology.CreateTopology ('ticket_5698', 4258 , 0);
 SELECT
 topology.TopoGeo_addLinestring('ticket_5698','0102000020A21000000B0000002576190B5B982F40D536C08AAA435140B7CCA3B24F982F40A2FBE5F6AA4351405EAB157B40982F40C4519D11AB4351405E0E9F9C23982F408F275902AB43514023D3944915982F408072C93EAB435140B4FABED907982F40BEB366B5AB43514053004595F5972F40ABDB269BAB43514020B686EBE7972F4014736C4AAB435140E64F4C20E3972F40C3F7E7D9AA4351404D2D7558F1972F40C13463C8A84351406866DEF2F0972F40F6725352A8435140');
 SELECT
 topology.TopoGeo_addLinestring('ticket_5698','0102000020A2100000040000006866DEF2F0972F40F6725352A84351406D38AE82F0972F40EDE9EA43A74351408C2F03C9FE972F4032A7D9DBA64351407DBD073900982F40E03769D7A6435140');
 SELECT
 topology.TopoGeo_addLinestring('ticket_5698','0102000020A210000003000000FFFB9BAC61982F40000E0A24A9435140E57F1F995F982F40B269A428AA4351402576190B5B982F40D536C08AAA435140');
 SELECT
 topology.TopoGeo_addLinestring('ticket_5698','0102000020A2100000030000007DBD073900982F40E03769D7A64351400E3838CC09982F407BF5CA22A9435140FFFB9BAC61982F40000E0A24A9435140');
 SELECT
 topology.TopoGeo_addLinestring('ticket_5698','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');
 SELECT
 topology.TopoGeo_addLinestring('ticket_5698','0102000020A2100000050000006866DEF2F0972F40F6725352A8435140BF3E78E2D4972F402F5A18C5A8435140377EBB1CC3972F4057E58320A94351400335ACCE8B972F408DACCE07AA4351402DD62D1E81972F405D3E341CAA435140');
 Then we add this line which is closed,
 SELECT
 topology.TopoGeo_addLinestring('ticket_5698','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',0);
 and we get the same error
 ERROR:  XX000: SQL/MM Spatial exception - point not on edge
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5698#comment:4>
