[PostGIS] #5699: ERROR: XX000: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Thu Mar 21 23:39:32 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  pramsey
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  postgis            |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 Here the problem seems to be that just before adding the last the line
 topology is invalid and that seems to happen silently when adding the
 lines from the attached file as see we in this check.
 select ValidateTopology('tmp_dyrkbarjord_04_t3_a_test_issue_70_87');
 returns this before adding the last line
            validatetopology
  ("edge crosses edge",65,77)
  ("hole not in advertised face",-112,)
  ("hole not in advertised face",-111,)
  ("hole not in advertised face",-91,)
 (4 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5699#comment:1>
