[PostGIS] #5698: XX000: SQL/MM Spatial exception - point not on edge
PostGIS trac at osgeo.org
Fri Mar 22 03:56:42 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by strk):
 I can reproduce with
 POSTGIS="3.5.0dev 3.4.0rc1-1039-g88c3893c7" [EXTENSION] PGSQL="150"
 GEOS="3.12.2dev-CAPI-1.18.2"
 Further simplified:
 SELECT topology.CreateTopology ('ticket_5698');
 SELECT topology.TopoGeo_addLinestring('ticket_5698','LINESTRING(
 15.796760167740288 69.05714853429149,
 15.795906966300288 69.05725770093837)');
 SELECT topology.TopoGeo_addLinestring('ticket_5698', 'LINESTRING(
 15.79762019616626 69.05719853383958,
 15.796760167739626 69.05714853429157)');
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5698#comment:5>
