[PostGIS] #5672: Function ST_3DIntersects does not work for MULTILINESTRING and LINESTRING.
PostGIS trac at osgeo.org
Fri Mar 22 04:10:14 PDT 2024
  Reporter:  Wenjing  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by Wenjing):
 Paul, did you have a chance to look at this one? It is very strange.
 @pramsey
 The test cases with two same lines only containing two points trigger this
 kind of issue.
 Replacing MULTILINESTRING with LINESTRING triggers it as well.
 SELECT ST_3DIntersects(b1, b2)
     FROM ST_GeomFromText('LINESTRING Z (1 0 0, 0 0 0)')
     As b1,
     As b2;
 -- actual{f}; expected{t}
 However, reordering the points does not.
     FROM ST_GeomFromText('LINESTRING Z (0 0 0,1 0 0)')
     As b1,
     ST_GeomFromText('LINESTRING Z (1 0 0,0 0 0)')
     As b2;
 -- result{t}
 Meanwhile, adding a point avoids triggering it.
     FROM ST_GeomFromText('MULTILINESTRING Z ((2 0 0,1 0 0,0 0 0))')
     As b1,
     ST_GeomFromText('LINESTRING Z (2 0 0,1 0 0,0 0 0)')
     As b2;
 -- result{t}
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5672#comment:1>
