[SCM] PostGIS branch master updated. 3.4.0rc1-1041-g5e5afc046
Fri Mar 22 10:10:53 PDT 2024
the project "PostGIS".
       via  5e5afc046bb84c72b5c3831c455c86b2b5f53391 (commit)
      from  d37594dfafb21a71119252fe06bf05d9fc79b796 (commit)
revisions in full, below.
commit 5e5afc046bb84c72b5c3831c455c86b2b5f53391
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Mar 22 17:11:23 2024 +0100
    Fix lwline_split_by_point_to determination of boundary points
    Replaces tolerance-based p4d_same usage with the stricter
    P4D_SAME_STRICT macro, now exposed in liblwgeom_internal.h
    References #5698 in master branch (3.5.0dev)
    Includes unit test
diff --git a/liblwgeom/cunit/cu_split.c b/liblwgeom/cunit/cu_split.c
index edbf00aa4..223fcd071 100644
--- a/liblwgeom/cunit/cu_split.c
+++ b/liblwgeom/cunit/cu_split.c
@@ -271,6 +271,18 @@ static void test_lwgeom_split(void)
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
+	/* See #5698 -- robustness issue */
+	geom = lwgeom_from_wkt("LINESTRING(15.796760167740288 69.05714853429149,15.796760167739626 69.05714853429157,15.795906966300288 69.05725770093837)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_FATAL(geom != NULL);
+	blade = lwpoint_as_lwgeom(lwline_get_lwpoint(lwgeom_as_lwline(geom), 1));
+	CU_ASSERT(blade != NULL);
+	ret = lwgeom_split(geom, blade);
+	CU_ASSERT_FATAL(ret != NULL);
+	ASSERT_INT_EQUAL( lwgeom_as_lwcollection(ret)->ngeoms, 2 );
+	lwgeom_free(ret);
+	lwgeom_free(geom);
+	lwgeom_free(blade);
 static int
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index 5428d1f24..f1e28eac0 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -247,13 +247,22 @@ lwvarlena_t *geohash_point(double longitude, double latitude, int precision);
 void decode_geohash_bbox(char *geohash, double *lat, double *lon, int precision);
-* Point comparisons
+* Point comparisons (FP tolerance based)
 int p4d_same(const POINT4D *p1, const POINT4D *p2);
 int p3d_same(const POINT3D *p1, const POINT3D *p2);
 int p3dz_same(const POINT3DZ *p1, const POINT3DZ *p2);
 int p2d_same(const POINT2D *p1, const POINT2D *p2);
+ * Non-tolerance based equality for points
+ * whereas the p#d_same function are tolerance based
+#define P2D_SAME_STRICT(a,b) ((a)->x == (b)->x && (a)->y == (b)->y)
+#define P3DZ_SAME_STRICT(a,b) ((a)->x == (b)->x && (a)->y == (b)->y && (a)->z == (b)->z )
+#define P3DM_SAME_STRICT(a,b) ((a)->x == (b)->x && (a)->y == (b)->y && (a)->m == (b)->m )
+#define P4D_SAME_STRICT(a,b) ((a)->x == (b)->x && (a)->y == (b)->y && (a)->z == (b)->z && (a)->m == (b)->m )
 * Projections
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index 901a1ac14..724ff7754 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -240,7 +240,7 @@ lwline_split_by_point_to(const LWLINE* lwline_in, const LWPOINT* blade_in,
 		getPoint4d_p(ipa, i+1, &p2);
 		double dist_sqr = distance2d_sqr_pt_seg((POINT2D *)&pt, (POINT2D *)&p1, (POINT2D *)&p2);
-		LWDEBUGF(4, "Distance (squared) of point %g %g to segment %g %g, %g %g: %g",
+		LWDEBUGF(4, "Distance (squared) of point %.15g %.15g to segment %.15g %.15g, %.15g %.15g: %.15g",
 				 pt.x, pt.y,
 				 p1.x, p1.y,
 				 p2.x, p2.y,
@@ -256,7 +256,7 @@ lwline_split_by_point_to(const LWLINE* lwline_in, const LWPOINT* blade_in,
 	LWDEBUGF(3, "Closest segment: %d", seg);
-	LWDEBUGF(3, "mindist: %g", mindist_sqr);
+	LWDEBUGF(3, "mindist: %.15g", mindist_sqr);
 	/* No intersection */
 	if (mindist_sqr > 0)
@@ -280,11 +280,11 @@ lwline_split_by_point_to(const LWLINE* lwline_in, const LWPOINT* blade_in,
 	pt_projected.x = pt.x;
 	pt_projected.y = pt.y;
-	LWDEBUGF(3, "Projected point:(%g %g), seg:%d, p1:(%g %g), p2:(%g %g)", pt_projected.x, pt_projected.y, seg, p1.x, p1.y, p2.x, p2.y);
+	LWDEBUGF(3, "Projected point:(%.15g %.15g), seg:%d, p1:(%.15g %.15g), p2:(%.15g %.15g)", pt_projected.x, pt_projected.y, seg, p1.x, p1.y, p2.x, p2.y);
 	/* When closest point == an endpoint, this is a boundary intersection */
-	if ( ( (seg == nsegs-1) && p4d_same(&pt_projected, &p2) ) ||
-	     ( (seg == 0)       && p4d_same(&pt_projected, &p1) ) )
+	if ( ( (seg == nsegs-1) && P4D_SAME_STRICT(&pt_projected, &p2) ) ||
+	     ( (seg == 0)       && P4D_SAME_STRICT(&pt_projected, &p1) ) )
 		return 1;
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index c00fa027c..73a539235 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -33,12 +33,6 @@
 #include "liblwgeom_topo_internal.h"
 #include "lwgeom_geos.h"
-/* This is a non-tolerance based 2d equality for points
- * whereas the p2d_same function is tolerance based
- * TODO: move in higher headers ?
-#define P2D_SAME_STRICT(a,b) ((a)->x == (b)->x && (a)->y == (b)->y)
  * Backend iface
Summary of changes:
 liblwgeom/cunit/cu_split.c     | 12 ++++++++++++
 liblwgeom/liblwgeom_internal.h | 11 ++++++++++-
 liblwgeom/lwgeom_geos_split.c  | 10 +++++-----
 liblwgeom/topo/lwgeom_topo.c   |  6 ------
 4 files changed, 27 insertions(+), 12 deletions(-)
hooks/post-receive
