[PostGIS] #5698: XX000: SQL/MM Spatial exception - point not on edge
PostGIS trac at osgeo.org
Fri Mar 22 10:24:29 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.4.3
 Component:  topology           |    Version:  3.4.x
Resolution:                     |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"3d8226d5cbe14461b1bfe75432245cce2c8455ec/git" 3d8226d/git]:
 {{{#!CommitTicketReference repository="git"
 revision="3d8226d5cbe14461b1bfe75432245cce2c8455ec"
 Fix lwline_split_by_point_to determination of boundary points
 Replaces tolerance-based p4d_same usage with the stricter
 P4D_SAME_STRICT macro, now exposed in liblwgeom_internal.h
 References #5698 in 3.4 branch (3.4.3dev)
 Includes unit test for lwline_split_by_point_to
 and regress test for TopoGeo_addPoint
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5698#comment:14>
