[SCM] PostGIS branch stable-3.4 updated. 3.4.2-23-gd5d34567c
Fri Mar 22 10:27:24 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  d5d34567c357f9b3d79de3b5256b43b666b1e85b (commit)
      from  3d8226d5cbe14461b1bfe75432245cce2c8455ec (commit)
revisions in full, below.
commit d5d34567c357f9b3d79de3b5256b43b666b1e85b
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Mar 22 18:27:09 2024 +0100
    Add NEWS item about the fix for #5698
diff --git a/NEWS b/NEWS
index f4328da1a..0f8817efb 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,8 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
 * Bug Fixes *
+ - #5698, Fix robustness issue splitting line by vertex very close to endpoints,
+          affecting topology population functions (Sandro Santilli)
  - #5649, ST_Value should return NULL on missing band (Paul Ramsey)
  - #5677, ST_Union(geom[]) should unary union single entry arrays (Paul Ramsey)
  - #5679, Remove spurious COMMIT statements from sfcgal script
@@ -15,7 +17,7 @@ To take advantage of all SFCGAL featurs, SFCGAL 1.4.1+ is needed.
           set to off (Sandro Santilli)
  - #5589, ST_3DDistance error for shared first point (Paul Ramsey)
  - #5686, ST_NumInteriorRings and Triangle crash (Paul Ramsey)
- - #5666, Build reproducibility: timestamps
+ - #5666, Build reproducibility: timestamps
           in extension upgrade SQL scripts (James Addison)
  - #5671, Bug in ST_Area function with use_spheroid=false
           (Paul Ramsey, Regina Obe)
Summary of changes:
 NEWS | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
hooks/post-receive
