[PostGIS] #5698: XX000: SQL/MM Spatial exception - point not on edge
PostGIS trac at osgeo.org
Fri Mar 22 10:38:57 PDT 2024
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  closed
  Priority:  medium             |  Milestone:  PostGIS 3.3.7
 Component:  topology           |    Version:  2.5.x -- EOL
Resolution:  fixed              |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"850982a195fca5c08faddc1a4d929a3c6c3d378f/git" 850982a/git]:
 {{{#!CommitTicketReference repository="git"
 revision="850982a195fca5c08faddc1a4d929a3c6c3d378f"
 Fix lwline_split_by_point_to determination of boundary points
 Replaces tolerance-based p4d_same usage with the stricter
 P4D_SAME_STRICT macro, now exposed in liblwgeom_internal.h
 Closes #5698 in 3.3 branch (3.3.7dev)
 Includes unit test for lwline_split_by_point_to
 and regress test for TopoGeo_addPoint
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5698#comment:16>
