[SCM] PostGIS branch master updated. 3.4.0rc1-1044-ga7ad55a4e
Fri Mar 22 18:46:32 PDT 2024
the project "PostGIS".
       via  a7ad55a4e92fda4cbbd71b95a710a48fb24907ee (commit)
       via  3085fb74de93e63951afcaffb7975ed2cb849ca6 (commit)
      from  a5b7632c451016065415f1999616c220125e35cd (commit)
revisions in full, below.
commit a7ad55a4e92fda4cbbd71b95a710a48fb24907ee
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Mar 22 21:46:17 2024 -0400
    Try to fix woodpecker bad_habit warning
diff --git a/.woodpecker/docs-localized.yml.in b/.woodpecker/docs-localized.yml.in
index ece9af87e..382a8194f 100644
--- a/.woodpecker/docs-localized.yml.in
+++ b/.woodpecker/docs-localized.yml.in
@@ -5,6 +5,7 @@
       - make -C build-docs/doc/po/@LANG@ local- at TARGET@
     depends_on: @DEP@
     when:
-      path:
+      - event: [push, pull_request]
+        path:
         include:
           - "doc/po/@LANG@/*.po"
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 2c7c4870a..9a9b48012 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -90,7 +90,8 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/it_IT/*.po"
   check-xml-pt_BR:
@@ -100,7 +101,8 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/pt_BR/*.po"
   check-xml-fr:
@@ -110,7 +112,8 @@ steps:
       - make -C build-docs/doc/po/fr local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/fr/*.po"
   check-xml-es:
@@ -120,7 +123,8 @@ steps:
       - make -C build-docs/doc/po/es local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/es/*.po"
   check-xml-pl:
@@ -130,7 +134,8 @@ steps:
       - make -C build-docs/doc/po/pl local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/pl/*.po"
   check-xml-ko_KR:
@@ -140,7 +145,8 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/ko_KR/*.po"
   check-xml-de:
@@ -150,7 +156,8 @@ steps:
       - make -C build-docs/doc/po/de local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/de/*.po"
   check-xml-ja:
@@ -160,7 +167,8 @@ steps:
       - make -C build-docs/doc/po/ja local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/ja/*.po"
   check-xml-ru:
@@ -170,7 +178,8 @@ steps:
       - make -C build-docs/doc/po/ru local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/ru/*.po"
   check-xml-zh_Hans:
@@ -180,7 +189,8 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/zh_Hans/*.po"
   check-xml-ro:
@@ -190,7 +200,8 @@ steps:
       - make -C build-docs/doc/po/ro local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/ro/*.po"
   check-xml-uk:
@@ -200,7 +211,8 @@ steps:
       - make -C build-docs/doc/po/uk local-check-xml
     depends_on: prepare
     when:
-      path:
+        path:
         include:
           - "doc/po/uk/*.po"
 ### TARGET html
@@ -211,7 +223,8 @@ steps:
       - make -C build-docs/doc/po/it_IT local-html
     depends_on: check-xml-it_IT
     when:
-      path:
+        path:
         include:
   html-pt_BR:
@@ -221,7 +234,8 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-html
     depends_on: check-xml-pt_BR
     when:
-      path:
+        path:
         include:
   html-fr:
@@ -231,7 +245,8 @@ steps:
       - make -C build-docs/doc/po/fr local-html
     depends_on: check-xml-fr
     when:
-      path:
+        path:
         include:
           - "doc/po/fr/*.po"
   html-es:
@@ -241,7 +256,8 @@ steps:
       - make -C build-docs/doc/po/es local-html
     depends_on: check-xml-es
     when:
-      path:
+        path:
         include:
           - "doc/po/es/*.po"
   html-pl:
@@ -251,7 +267,8 @@ steps:
       - make -C build-docs/doc/po/pl local-html
     depends_on: check-xml-pl
     when:
-      path:
+        path:
         include:
           - "doc/po/pl/*.po"
   html-ko_KR:
@@ -261,7 +278,8 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-html
     depends_on: check-xml-ko_KR
     when:
-      path:
+        path:
         include:
   html-de:
@@ -271,7 +289,8 @@ steps:
       - make -C build-docs/doc/po/de local-html
     depends_on: check-xml-de
     when:
-      path:
+        path:
         include:
           - "doc/po/de/*.po"
   html-ja:
@@ -281,7 +300,8 @@ steps:
       - make -C build-docs/doc/po/ja local-html
     depends_on: check-xml-ja
     when:
-      path:
+        path:
         include:
           - "doc/po/ja/*.po"
   html-ru:
@@ -291,7 +311,8 @@ steps:
       - make -C build-docs/doc/po/ru local-html
     depends_on: check-xml-ru
     when:
-      path:
+        path:
         include:
           - "doc/po/ru/*.po"
   html-zh_Hans:
@@ -301,7 +322,8 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-html
     depends_on: check-xml-zh_Hans
     when:
-      path:
+        path:
         include:
   html-ro:
@@ -311,7 +333,8 @@ steps:
       - make -C build-docs/doc/po/ro local-html
     depends_on: check-xml-ro
     when:
-      path:
+        path:
         include:
           - "doc/po/ro/*.po"
   html-uk:
@@ -321,7 +344,8 @@ steps:
       - make -C build-docs/doc/po/uk local-html
     depends_on: check-xml-uk
     when:
-      path:
+        path:
         include:
           - "doc/po/uk/*.po"
 ### TARGET cheatsheets
@@ -332,7 +356,8 @@ steps:
       - make -C build-docs/doc/po/it_IT local-cheatsheets
     when:
-      path:
+        path:
         include:
   cheatsheets-pt_BR:
@@ -342,7 +367,8 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-cheatsheets
     when:
-      path:
+        path:
         include:
   cheatsheets-fr:
@@ -352,7 +378,8 @@ steps:
       - make -C build-docs/doc/po/fr local-cheatsheets
     when:
-      path:
+        path:
         include:
           - "doc/po/fr/*.po"
   cheatsheets-es:
@@ -362,7 +389,8 @@ steps:
       - make -C build-docs/doc/po/es local-cheatsheets
     when:
-      path:
+        path:
         include:
           - "doc/po/es/*.po"
   cheatsheets-pl:
@@ -372,7 +400,8 @@ steps:
       - make -C build-docs/doc/po/pl local-cheatsheets
     when:
-      path:
+        path:
         include:
           - "doc/po/pl/*.po"
   cheatsheets-ko_KR:
@@ -382,7 +411,8 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-cheatsheets
     when:
-      path:
+        path:
         include:
   cheatsheets-de:
@@ -392,7 +422,8 @@ steps:
       - make -C build-docs/doc/po/de local-cheatsheets
     when:
-      path:
+        path:
         include:
           - "doc/po/de/*.po"
   cheatsheets-ja:
@@ -402,7 +433,8 @@ steps:
       - make -C build-docs/doc/po/ja local-cheatsheets
     when:
-      path:
+        path:
         include:
           - "doc/po/ja/*.po"
   cheatsheets-ru:
@@ -412,7 +444,8 @@ steps:
       - make -C build-docs/doc/po/ru local-cheatsheets
     when:
-      path:
+        path:
         include:
           - "doc/po/ru/*.po"
   cheatsheets-zh_Hans:
@@ -422,7 +455,8 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-cheatsheets
     when:
-      path:
+        path:
         include:
   cheatsheets-ro:
@@ -432,7 +466,8 @@ steps:
       - make -C build-docs/doc/po/ro local-cheatsheets
     when:
-      path:
+        path:
         include:
           - "doc/po/ro/*.po"
   cheatsheets-uk:
@@ -442,7 +477,8 @@ steps:
       - make -C build-docs/doc/po/uk local-cheatsheets
     when:
-      path:
+        path:
         include:
           - "doc/po/uk/*.po"
 ### TARGET check-cheatsheets
@@ -453,7 +489,8 @@ steps:
       - make -C build-docs/doc/po/it_IT local-check-cheatsheets
     depends_on: [ cheatsheets-it_IT, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
   check-cheatsheets-pt_BR:
@@ -463,7 +500,8 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-check-cheatsheets
     depends_on: [ cheatsheets-pt_BR, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
   check-cheatsheets-fr:
@@ -473,7 +511,8 @@ steps:
       - make -C build-docs/doc/po/fr local-check-cheatsheets
     depends_on: [ cheatsheets-fr, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
           - "doc/po/fr/*.po"
   check-cheatsheets-es:
@@ -483,7 +522,8 @@ steps:
       - make -C build-docs/doc/po/es local-check-cheatsheets
     depends_on: [ cheatsheets-es, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
           - "doc/po/es/*.po"
   check-cheatsheets-pl:
@@ -493,7 +533,8 @@ steps:
       - make -C build-docs/doc/po/pl local-check-cheatsheets
     depends_on: [ cheatsheets-pl, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
           - "doc/po/pl/*.po"
   check-cheatsheets-ko_KR:
@@ -503,7 +544,8 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-check-cheatsheets
     depends_on: [ cheatsheets-ko_KR, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
   check-cheatsheets-de:
@@ -513,7 +555,8 @@ steps:
       - make -C build-docs/doc/po/de local-check-cheatsheets
     depends_on: [ cheatsheets-de, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
           - "doc/po/de/*.po"
   check-cheatsheets-ja:
@@ -523,7 +566,8 @@ steps:
       - make -C build-docs/doc/po/ja local-check-cheatsheets
     depends_on: [ cheatsheets-ja, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
           - "doc/po/ja/*.po"
   check-cheatsheets-ru:
@@ -533,7 +577,8 @@ steps:
       - make -C build-docs/doc/po/ru local-check-cheatsheets
     depends_on: [ cheatsheets-ru, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
           - "doc/po/ru/*.po"
   check-cheatsheets-zh_Hans:
@@ -543,7 +588,8 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-check-cheatsheets
     depends_on: [ cheatsheets-zh_Hans, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
   check-cheatsheets-ro:
@@ -553,7 +599,8 @@ steps:
       - make -C build-docs/doc/po/ro local-check-cheatsheets
     depends_on: [ cheatsheets-ro, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
           - "doc/po/ro/*.po"
   check-cheatsheets-uk:
@@ -563,7 +610,8 @@ steps:
       - make -C build-docs/doc/po/uk local-check-cheatsheets
     depends_on: [ cheatsheets-uk, build-cheatsheets ]
     when:
-      path:
+        path:
         include:
           - "doc/po/uk/*.po"
 ### TARGET pdf
@@ -574,7 +622,8 @@ steps:
       - make -C build-docs/doc/po/it_IT local-pdf
     depends_on: [ build-images, check-xml-it_IT ]
     when:
-      path:
+        path:
         include:
   pdf-pt_BR:
@@ -584,7 +633,8 @@ steps:
       - make -C build-docs/doc/po/pt_BR local-pdf
     depends_on: [ build-images, check-xml-pt_BR ]
     when:
-      path:
+        path:
         include:
   pdf-fr:
@@ -594,7 +644,8 @@ steps:
       - make -C build-docs/doc/po/fr local-pdf
     depends_on: [ build-images, check-xml-fr ]
     when:
-      path:
+        path:
         include:
           - "doc/po/fr/*.po"
   pdf-es:
@@ -604,7 +655,8 @@ steps:
       - make -C build-docs/doc/po/es local-pdf
     depends_on: [ build-images, check-xml-es ]
     when:
-      path:
+        path:
         include:
           - "doc/po/es/*.po"
   pdf-pl:
@@ -614,7 +666,8 @@ steps:
       - make -C build-docs/doc/po/pl local-pdf
     depends_on: [ build-images, check-xml-pl ]
     when:
-      path:
+        path:
         include:
           - "doc/po/pl/*.po"
   pdf-ko_KR:
@@ -624,7 +677,8 @@ steps:
       - make -C build-docs/doc/po/ko_KR local-pdf
     depends_on: [ build-images, check-xml-ko_KR ]
     when:
-      path:
+        path:
         include:
   pdf-de:
@@ -634,7 +688,8 @@ steps:
       - make -C build-docs/doc/po/de local-pdf
     depends_on: [ build-images, check-xml-de ]
     when:
-      path:
+        path:
         include:
           - "doc/po/de/*.po"
   pdf-ja:
@@ -644,7 +699,8 @@ steps:
       - make -C build-docs/doc/po/ja local-pdf
     depends_on: [ build-images, check-xml-ja ]
     when:
-      path:
+        path:
         include:
           - "doc/po/ja/*.po"
   pdf-ru:
@@ -654,7 +710,8 @@ steps:
       - make -C build-docs/doc/po/ru local-pdf
     depends_on: [ build-images, check-xml-ru ]
     when:
-      path:
+        path:
         include:
           - "doc/po/ru/*.po"
   pdf-zh_Hans:
@@ -664,7 +721,8 @@ steps:
       - make -C build-docs/doc/po/zh_Hans local-pdf
     depends_on: [ build-images, check-xml-zh_Hans ]
     when:
-      path:
+        path:
         include:
   pdf-ro:
@@ -674,7 +732,8 @@ steps:
       - make -C build-docs/doc/po/ro local-pdf
     depends_on: [ build-images, check-xml-ro ]
     when:
-      path:
+        path:
         include:
           - "doc/po/ro/*.po"
   pdf-uk:
@@ -684,6 +743,7 @@ steps:
       - make -C build-docs/doc/po/uk local-pdf
     depends_on: [ build-images, check-xml-uk ]
     when:
-      path:
+        path:
         include:
           - "doc/po/uk/*.po"
commit 3085fb74de93e63951afcaffb7975ed2cb849ca6
Date:   Fri Mar 22 21:37:59 2024 -0400
    Increase alloted time some more for interrupt buffer and relate
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index eb7a00893..949fc7e28 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -21,7 +21,7 @@ SET statement_timeout TO 100;
 select ST_Buffer(g,100) from _inputs WHERE id = 1;
 --( select (st_dumppoints(st_buffer(st_makepoint(0,0),10000,100000))).geom g) foo;
 -- it may take some more to interrupt st_buffer, see
-SELECT _timecheck('buffer', '300ms');
+SELECT _timecheck('buffer', '350ms');
 -- Not affected by old timeout
 SELECT '1', ST_NPoints(ST_Buffer('POINT(4 0)'::geometry, 2, 1));
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index 547caa2bc..d80dacf1c 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -19,32 +19,32 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
 select ST_Contains(g,g) from _inputs WHERE id = 1; -- 6+ seconds
-SELECT _timecheck('contains', '200ms');
+SELECT _timecheck('contains', '220ms');
 select ST_Covers(g,g) from _inputs WHERE id = 1; -- 6+ seconds
-SELECT _timecheck('covers', '200ms');
+SELECT _timecheck('covers', '220ms');
 select ST_CoveredBy(g,g) from _inputs WHERE id = 1; -- 6+ seconds
-SELECT _timecheck('coveredby', '200ms');
+SELECT _timecheck('coveredby', '250ms');
 select ST_Crosses(g,g) from _inputs WHERE id = 1; -- 6+ seconds
-SELECT _timecheck('crosses', '200ms');
+SELECT _timecheck('crosses', '220ms');
 -- NOTE: we're reversing one of the operands to avoid the
 --       short-circuit described in #3226
 select ST_Equals(g,st_reverse(g)) from _inputs WHERE id = 1; -- 6+ seconds
-SELECT _timecheck('equals', '200ms');
+SELECT _timecheck('equals', '220ms');
 -- NOTE: intersects became very fast, so we segmentize
 --       input to make it slower
 select ST_Intersects(g,ST_Segmentize(g,1e-4)) from _inputs WHERE id = 1; -- 6+ seconds
-SELECT _timecheck('intersects', '200ms');
+SELECT _timecheck('intersects', '210ms');
 select ST_Overlaps(g,g) from _inputs WHERE id = 1; -- 6+ seconds
-SELECT _timecheck('overlaps', '200ms');
+SELECT _timecheck('overlaps', '220ms');
 select ST_Relate(g,g) from _inputs WHERE id = 1; -- 6+ seconds
-SELECT _timecheck('relate', '200ms');
+SELECT _timecheck('relate', '220ms');
 DROP FUNCTION _timecheck(text, interval);
 DROP TABLE _inputs;
Summary of changes:
 .woodpecker/docs-localized.yml.in |   3 +-
 .woodpecker/docs.yml              | 180 +++++++++++++++++++++++++-------------
 regress/core/interrupt_buffer.sql |   2 +-
 regress/core/interrupt_relate.sql |  16 ++--
 4 files changed, 131 insertions(+), 70 deletions(-)
hooks/post-receive
