[SCM] PostGIS branch master updated. 3.4.0rc1-1071-gff91a5acd
Mon Mar 25 13:38:05 PDT 2024
the project "PostGIS".
       via  ff91a5acd205638bf6230c02391048883e0a4a35 (commit)
      from  d5ba6b71cf08baaf67d9646a7ca52d0dfb5c3e9c (commit)
revisions in full, below.
commit ff91a5acd205638bf6230c02391048883e0a4a35
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Mar 25 21:37:40 2024 +0100
    Fix spurious number in debug line
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index a0e262b03..370c82447 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -18,7 +18,7 @@
- * Copyright (C) 2015-2022 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2015-2024 Sandro Santilli <strk at kbt.io>
@@ -5441,7 +5441,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   lwpoint_free(start_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[0] == -1 ) return -1; /* lwerror should have been called */
   moved += mm;
-  LWDEBUGF(1, "start point added or found as being %" LWTFMT_ELEMID " (moved ? %d)", nid[1], mm);
+  LWDEBUGF(1, "node for start point added or found to be %" LWTFMT_ELEMID " (moved ? %d)", nid[0], mm);
   end_point = lwline_get_lwpoint(edge, edge->points->npoints-1);
@@ -5457,7 +5457,7 @@ _lwt_AddLineEdge( LWT_TOPOLOGY* topo, LWLINE* edge, double tol,
   lwpoint_free(end_point); /* too late if lwt_AddPoint calls lwerror */
   if ( nid[1] == -1 ) return -1; /* lwerror should have been called */
   moved += mm;
-  LWDEBUGF(1, "end point added or found as being %" LWTFMT_ELEMID " (moved ? %d)", nid[1], mm);
+  LWDEBUGF(1, "node for end point added or found to be %" LWTFMT_ELEMID " (moved ? %d)", nid[1], mm);
     -- Added endpoints may have drifted due to tolerance, so
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
