[PostGIS] #5701: topology crashing under PG17
PostGIS trac at osgeo.org
Wed Mar 27 08:20:29 PDT 2024
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.5.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Comment (by robe):
 I have confirmed this is not our fault.
 I can crash PG 17 with this query:
 CREATE TABLE edge_data AS
 SELECT i AS edge_id, i + 1 AS start_node, i + 2 As end_node
 FROM generate_series(1,10) AS i;
 CREATE TEMP TABLE edge1_endnodes AS
   WITH edge AS (
     SELECT start_node, end_node
     FROM edge_data
     WHERE edge_id = 1
   SELECT start_node id FROM edge UNION
   SELECT end_node FROM edge;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5701#comment:3>
