[SCM] PostGIS branch master updated. 3.4.0rc1-1075-g94437b681
Thu Mar 28 07:15:39 PDT 2024
the project "PostGIS".
       via  94437b68118a4cbee3a9b86e73c2b2971285aa6f (commit)
       via  b0698d29f76e10e76f1992905ad62dbda368c17e (commit)
       via  fd6071472a50c71af83f424e1effdd0ffd69c95a (commit)
       via  6e3f86d4ee82c4c16f80da97ad2c39b95be8daf4 (commit)
      from  ff91a5acd205638bf6230c02391048883e0a4a35 (commit)
revisions in full, below.
commit 94437b68118a4cbee3a9b86e73c2b2971285aa6f
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Mar 28 12:44:16 2024 +0100
    Fix check for enabled tests
    References #5704 in master branch (3.5.0dev)
diff --git a/utils/check_tests_enabled.sh b/utils/check_tests_enabled.sh
index bd186f8da..393c68355 100755
--- a/utils/check_tests_enabled.sh
+++ b/utils/check_tests_enabled.sh
@@ -20,7 +20,7 @@ check_enabled() {
   suffix=$2
   bd=`dirname ${mk}`/${suffix}
-  #cho "MK file: ${mk}"
+  #echo "MK file: ${mk}"
   #echo "Suffix: ${suffix}"
   #echo "Basedir: ${bd}"
@@ -31,15 +31,12 @@ check_enabled() {
   #cat ${TMPDIR}/enabled_tests
-  find ${bd} -name '*.sql' |
-    grep -v '\-post.sql' | grep -v '\-pre.sql' |
-    sed 's|\.select.sql$||' |
-    sed 's|//|/|' |
-    sed 's|\.sql$||' > ${TMPDIR}/available_tests
+  find ${bd} -name '*_expected' |
+    sed 's|_expected$||' > ${TMPDIR}/available_tests
   #cat ${TMPDIR}/available_tests
-  MISSING=`grep -vf ${TMPDIR}/enabled_tests ${TMPDIR}/available_tests`
+  MISSING=`grep -vwf ${TMPDIR}/enabled_tests ${TMPDIR}/available_tests`
   if test -n "${MISSING}"; then
     echo "The following tests are available but not enabled in:"
commit b0698d29f76e10e76f1992905ad62dbda368c17e
Date:   Thu Mar 28 12:45:53 2024 +0100
    Enable accidentally disabled tests
    These are:
      - regress/core/geography_centroid
      - regress/core/geography_covers
      - topology/test/regress/validatetopologyrelation.sql
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index dca602a6a..7e783d7b5 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -46,6 +46,8 @@ TESTS += \
 	$(top_srcdir)/regress/core/frechet \
 	$(top_srcdir)/regress/core/generate_points \
 	$(top_srcdir)/regress/core/geography \
+	$(top_srcdir)/regress/core/geography_centroid \
+	$(top_srcdir)/regress/core/geography_covers \
 	$(top_srcdir)/regress/core/geometric_median \
 	$(top_srcdir)/regress/core/geos_noop \
 	$(top_srcdir)/regress/core/geos38 \
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 5f148a6ca..02edc26fc 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -84,4 +84,5 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/topologysummary.sql \
 	$(top_srcdir)/topology/test/regress/totopogeom.sql \
 	$(top_srcdir)/topology/test/regress/validatetopology.sql \
+	$(top_srcdir)/topology/test/regress/validatetopologyrelation.sql \
 	$(top_srcdir)/topology/test/regress/topoelement_cast.sql
commit fd6071472a50c71af83f424e1effdd0ffd69c95a
Date:   Thu Mar 28 15:08:17 2024 +0100
    Make geography_centroid tests tolerant to subtle differences
    Check up to 10 decimal digits in text form
    The test otherwise fails with 3.13.0dev-CAPI-1.18.0
    but was not running in CI
diff --git a/regress/core/geography_centroid.sql b/regress/core/geography_centroid.sql
index 7e1edabbe..c8930d43b 100644
--- a/regress/core/geography_centroid.sql
+++ b/regress/core/geography_centroid.sql
@@ -23,7 +23,7 @@ SELECT c, ST_Centroid(g::geography) FROM
 ) AS u(c, g);
 -- test supported geometry types
-SELECT c, ST_Centroid(g::geography) FROM
+SELECT c, ST_AsText(ST_Centroid(g::geography), 10) FROM
 ( VALUES
     ('geog_centroid_sup_pt', 'POINT (23 42)'),
     ('geog_centroid_sup_line', 'LINESTRING(-20 35, 8 46)'),
diff --git a/regress/core/geography_centroid_expected b/regress/core/geography_centroid_expected
index 90375538e..270eced12 100644
--- a/regress/core/geography_centroid_expected
+++ b/regress/core/geography_centroid_expected
@@ -6,8 +6,8 @@ geog_centroid_mpt_idl_3|0101000020E610000000000000007066C00000000000000000
 geog_centroid_pt_self_1|0101000020E610000000000000000010400000000000002040
 geog_centroid_pt_self_2|0101000020E61000000000000000002EC00000000000003040
 geog_centroid_pt_self_3|0101000020E610000000000000000037C000000000000045C0
-geog_centroid_sup_pt|0101000020E610000000000000000037400000000000004540
-geog_centroid_sup_line|0101000020E6100000753A468ED7B21CC00371ADA1B0AC4440
-geog_centroid_sup_mline|0101000020E61000009809DA1111101440C8CB7BE13F784540
-geog_centroid_sup_poly|0101000020E610000032ABE2FEB2DB25407A5DAC8D5A574940
-geog_centroid_sup_mpoly|0101000020E6100000AA6CB8CF16543C40828564C8CE403940
+geog_centroid_sup_pt|POINT(23 42)
+geog_centroid_sup_line|POINT(-7.174650405 41.3491403672)
+geog_centroid_sup_mline|POINT(5.0156901159 42.9394494872)
+geog_centroid_sup_poly|POINT(10.9291000034 50.6824509708)
+geog_centroid_sup_mpoly|POINT(28.3284730745 25.2531552549)
commit 6e3f86d4ee82c4c16f80da97ad2c39b95be8daf4
Date:   Thu Mar 28 15:03:19 2024 +0100
    Fix geography_covers test syntax
    It was broken by 51ff306d3f32217d00e9511cfe9463ddb0523adb
    but the test was not running in CI
diff --git a/regress/core/geography_covers.sql b/regress/core/geography_covers.sql
index 721f2431a..4cc413622 100644
--- a/regress/core/geography_covers.sql
+++ b/regress/core/geography_covers.sql
@@ -41,7 +41,7 @@ SELECT c, ST_Covers(g::geography, g::geography) FROM
     ('geog_covers_self_point', 'POINT (0 20)'),
     ('geog_covers_self_line', 'LINESTRING (35 35, 35 15, 15 15)'),
     ('geog_covers_self_polygon', 'POLYGON((0 40, 40 40, 40 0, 0 0, 0 40))')
-) AS u(c, g)
+) AS u(c, g);
 -- donut covers
 SELECT 'geog_covers_donut', ST_Covers(
Summary of changes:
 regress/core/geography_centroid.sql      |  2 +-
 regress/core/geography_centroid_expected | 10 +++++-----
 regress/core/geography_covers.sql        |  2 +-
 regress/core/tests.mk.in                 |  2 ++
 topology/test/tests.mk                   |  1 +
 utils/check_tests_enabled.sh             | 11 ++++-------
 6 files changed, 14 insertions(+), 14 deletions(-)
hooks/post-receive
