[PostGIS] #5704: Some regress tests are available but not enabled
PostGIS trac at osgeo.org
Thu Mar 28 07:15:43 PDT 2024
  Reporter:  strk          |      Owner:  strk
      Type:  defect        |     Status:  new
  Priority:  medium        |  Milestone:  PostGIS 3.2.8
 Component:  QA/testsuite  |    Version:  3.2.x
Resolution:                |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"fd6071472a50c71af83f424e1effdd0ffd69c95a/git" fd60714/git]:
 {{{#!CommitTicketReference repository="git"
 revision="fd6071472a50c71af83f424e1effdd0ffd69c95a"
 Make geography_centroid tests tolerant to subtle differences
 Check up to 10 decimal digits in text form
 The test otherwise fails with 3.13.0dev-CAPI-1.18.0
 but was not running in CI
 References #5704 in master branch (3.5.0dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5704#comment:3>
