[SCM] PostGIS branch stable-3.3 updated. 3.3.6-16-g976f101b0
Thu Mar 28 07:32:52 PDT 2024
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  976f101b0b2cd472f2ec8bd5c2a86153e6e8c2c4 (commit)
       via  c82930f4453f7b698863a5436712f94c5552b442 (commit)
       via  63b8bab3692ef2cfe0bd4edece561496e88ba12b (commit)
      from  850982a195fca5c08faddc1a4d929a3c6c3d378f (commit)
revisions in full, below.
commit 976f101b0b2cd472f2ec8bd5c2a86153e6e8c2c4
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Mar 28 12:45:53 2024 +0100
    Enable accidentally disabled tests
    These are:
      - regress/core/geography_centroid
      - regress/core/geography_covers
      - topology/test/regress/validatetopologyrelation.sql
    References #5704 in 3.3 branch (3.3.7dev)
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 56b6e8edf..e1b6b987a 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -44,6 +44,8 @@ TESTS += \
 	$(top_srcdir)/regress/core/forcecurve \
 	$(top_srcdir)/regress/core/flatgeobuf \
 	$(top_srcdir)/regress/core/geography \
+	$(top_srcdir)/regress/core/geography_centroid \
+	$(top_srcdir)/regress/core/geography_covers \
 	$(top_srcdir)/regress/core/geometric_median \
   $(top_srcdir)/regress/core/geos_noop \
 	$(top_srcdir)/regress/core/hausdorff \
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index b472a5675..937e3e3cd 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -80,4 +80,5 @@ TESTS += \
 	$(top_srcdir)/topology/test/regress/topojson.sql \
 	$(top_srcdir)/topology/test/regress/topologysummary.sql \
 	$(top_srcdir)/topology/test/regress/totopogeom.sql \
-	$(top_srcdir)/topology/test/regress/validatetopology.sql
+	$(top_srcdir)/topology/test/regress/validatetopology.sql \
+	$(top_srcdir)/topology/test/regress/validatetopologyrelation.sql
commit c82930f4453f7b698863a5436712f94c5552b442
Date:   Thu Mar 28 12:44:16 2024 +0100
    Fix check for enabled tests
diff --git a/utils/check_tests_enabled.sh b/utils/check_tests_enabled.sh
index b8f69f83c..caaca5ceb 100755
--- a/utils/check_tests_enabled.sh
+++ b/utils/check_tests_enabled.sh
@@ -21,7 +21,7 @@ check_enabled() {
   suffix=$2
   bd=`dirname ${mk}`/${suffix}
-  #cho "MK file: ${mk}"
+  #echo "MK file: ${mk}"
   #echo "Suffix: ${suffix}"
   #echo "Basedir: ${bd}"
@@ -32,15 +32,12 @@ check_enabled() {
   #cat ${TMPDIR}/enabled_tests
-  find ${bd} -name '*.sql' |
-    grep -v '\-post.sql' | grep -v '\-pre.sql' |
-    sed 's|\.select.sql$||' |
-    sed 's|//|/|' |
-    sed 's|\.sql$||' > ${TMPDIR}/available_tests
+  find ${bd} -name '*_expected' |
+    sed 's|_expected$||' > ${TMPDIR}/available_tests
   #cat ${TMPDIR}/available_tests
-  MISSING=`grep -vf ${TMPDIR}/enabled_tests ${TMPDIR}/available_tests`
+  MISSING=`grep -vwf ${TMPDIR}/enabled_tests ${TMPDIR}/available_tests`
   if test -n "${MISSING}"; then
     echo "The following tests are available but not enabled in:"
@@ -76,9 +73,18 @@ if [ -z "${RD}" ]; then
 fi
 cd ${RD}
-check_enabled topology/test/tests.mk regress &&
-check_enabled regress/loader/tests.mk &&
-check_enabled regress/dumper/tests.mk &&
-check_enabled sfcgal/regress/tests.mk.in &&
-check_enabled regress/core/tests.mk.in &&
+err=0
+check_enabled topology/test/tests.mk regress
+err=$(($err+$?))
+check_enabled regress/loader/tests.mk
+err=$(($err+$?))
+check_enabled regress/dumper/tests.mk
+err=$(($err+$?))
+check_enabled sfcgal/regress/tests.mk.in
+err=$(($err+$?))
+check_enabled regress/core/tests.mk.in
+err=$(($err+$?))
 check_enabled raster/test/regress/tests.mk
+err=$(($err+$?))
+exit $err
commit 63b8bab3692ef2cfe0bd4edece561496e88ba12b
Date:   Thu Mar 28 15:08:17 2024 +0100
    Make geography_centroid tests tolerant to subtle differences
    Check up to 10 decimal digits in text form
    The test otherwise fails with 3.13.0dev-CAPI-1.18.0
    but was not running in CI
diff --git a/regress/core/geography_centroid.sql b/regress/core/geography_centroid.sql
index 7e1edabbe..c8930d43b 100644
--- a/regress/core/geography_centroid.sql
+++ b/regress/core/geography_centroid.sql
@@ -23,7 +23,7 @@ SELECT c, ST_Centroid(g::geography) FROM
 ) AS u(c, g);
 -- test supported geometry types
-SELECT c, ST_Centroid(g::geography) FROM
+SELECT c, ST_AsText(ST_Centroid(g::geography), 10) FROM
 ( VALUES
     ('geog_centroid_sup_pt', 'POINT (23 42)'),
     ('geog_centroid_sup_line', 'LINESTRING(-20 35, 8 46)'),
diff --git a/regress/core/geography_centroid_expected b/regress/core/geography_centroid_expected
index 90375538e..270eced12 100644
--- a/regress/core/geography_centroid_expected
+++ b/regress/core/geography_centroid_expected
@@ -6,8 +6,8 @@ geog_centroid_mpt_idl_3|0101000020E610000000000000007066C00000000000000000
 geog_centroid_pt_self_1|0101000020E610000000000000000010400000000000002040
 geog_centroid_pt_self_2|0101000020E61000000000000000002EC00000000000003040
 geog_centroid_pt_self_3|0101000020E610000000000000000037C000000000000045C0
-geog_centroid_sup_pt|0101000020E610000000000000000037400000000000004540
-geog_centroid_sup_line|0101000020E6100000753A468ED7B21CC00371ADA1B0AC4440
-geog_centroid_sup_mline|0101000020E61000009809DA1111101440C8CB7BE13F784540
-geog_centroid_sup_poly|0101000020E610000032ABE2FEB2DB25407A5DAC8D5A574940
-geog_centroid_sup_mpoly|0101000020E6100000AA6CB8CF16543C40828564C8CE403940
+geog_centroid_sup_pt|POINT(23 42)
+geog_centroid_sup_line|POINT(-7.174650405 41.3491403672)
+geog_centroid_sup_mline|POINT(5.0156901159 42.9394494872)
+geog_centroid_sup_poly|POINT(10.9291000034 50.6824509708)
+geog_centroid_sup_mpoly|POINT(28.3284730745 25.2531552549)
Summary of changes:
 regress/core/geography_centroid.sql      |  2 +-
 regress/core/geography_centroid_expected | 10 +++++-----
 regress/core/tests.mk.in                 |  2 ++
 topology/test/tests.mk                   |  3 ++-
 utils/check_tests_enabled.sh             | 30 ++++++++++++++++++------------
 5 files changed, 28 insertions(+), 19 deletions(-)
hooks/post-receive
