[PostGIS] #5704: Some regress tests are available but not enabled
PostGIS trac at osgeo.org
Thu Mar 28 07:36:40 PDT 2024
  Reporter:  strk          |      Owner:  strk
      Type:  defect        |     Status:  closed
  Priority:  medium        |  Milestone:  PostGIS 3.2.8
 Component:  QA/testsuite  |    Version:  3.2.x
Resolution:  fixed         |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"be8b258d264f243e482731e3af3fdea1f61f1041/git"
 be8b258d/git]:
 {{{#!CommitTicketReference repository="git"
 revision="be8b258d264f243e482731e3af3fdea1f61f1041"
 Fix check for enabled tests
 Closes #5704 in 3.2 branch (3.2.8)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5704#comment:14>
