[PostGIS] #5704: Some regress tests are available but not enabled
PostGIS trac at osgeo.org
Sat Mar 30 00:45:07 PDT 2024
  Reporter:  strk          |      Owner:  strk
      Type:  defect        |     Status:  reopened
  Priority:  medium        |  Milestone:  PostGIS 3.2.8
 Component:  QA/testsuite  |    Version:  3.2.x
Resolution:                |   Keywords:
Comment (by robe):
 This looks to be just a rounding issue so will fix:
 {{{ -- POINT(179.49999999999997 0)
 SELECT
 ST_ASText('0101000020E6100000FFFFFFFFFF6F66400000000000000000'::geometry);
 -- POINT(179.5 0)
 SELECT
 ST_ASText('0101000020E610000000000000007066400000000000000000'::geometry);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5704#comment:16>
