[PostGIS] #5704: Some regress tests are available but not enabled
PostGIS trac at osgeo.org
Sat Mar 30 01:24:18 PDT 2024
  Reporter:  strk          |      Owner:  strk
      Type:  defect        |     Status:  reopened
  Priority:  medium        |  Milestone:  PostGIS 3.2.8
 Component:  QA/testsuite  |    Version:  3.2.x
Resolution:                |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 Will backport once confirmed works on master.  For the record berrie and
 berrie64 had the same issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5704#comment:18>
