[SCM] PostGIS branch master updated. 3.4.0rc1-1078-gebad0ba10
Sat Mar 30 02:06:17 PDT 2024
the project "PostGIS".
  discards  72152195d252e989db9d9d802c3ee9a285917d80 (commit)
       via  ebad0ba104f6dbe0b381e42ae079375043189dbf (commit)
This update added new revisions after undoing existing revisions.  That is
to say, the old revision is not a strict subset of the new revision.  This
situation occurs when you --force push a change and generate a repository
containing something like this:
 * -- * -- B -- O -- O -- O (72152195d252e989db9d9d802c3ee9a285917d80)
             N -- N -- N (ebad0ba104f6dbe0b381e42ae079375043189dbf)
When this happens we assume that you've already had alert emails for all
of the O revisions, and so we here report only the revisions in the N
branch from the common base, B.
revisions in full, below.
commit ebad0ba104f6dbe0b381e42ae079375043189dbf
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Mar 30 04:08:19 2024 -0400
    Fix regression issue on 32-bit
    and arm failures
    References #5704 for PostGIS 3.5.0
diff --git a/regress/core/geography_centroid.sql b/regress/core/geography_centroid.sql
index c8930d43b..31626466a 100644
--- a/regress/core/geography_centroid.sql
+++ b/regress/core/geography_centroid.sql
@@ -7,7 +7,7 @@ SELECT c, ST_Centroid(g::geography) FROM
 ) AS u(c, g);
 -- check for IDL crossing
-SELECT c, ST_Centroid(g::geography) FROM
+SELECT c, ST_AsText(ST_Centroid(g::geography),8) FROM
 ( VALUES
     ('geog_centroid_mpt_idl_1', 'MULTIPOINT ( 179 0, -179 0)'),
     ('geog_centroid_mpt_idl_2', 'MULTIPOINT ( 178 0, -179 0)'),
diff --git a/regress/core/geography_centroid_expected b/regress/core/geography_centroid_expected
index 270eced12..786075433 100644
--- a/regress/core/geography_centroid_expected
+++ b/regress/core/geography_centroid_expected
@@ -1,8 +1,8 @@
 geog_centroid_mpt_pole_north|0101000020E610000000000000000000000000000000805640
 geog_centroid_mpt_pole_south|0101000020E6100000000000000000000000000000008056C0
-geog_centroid_mpt_idl_1|0101000020E610000000000000008066400000000000000000
-geog_centroid_mpt_idl_2|0101000020E610000000000000007066400000000000000000
-geog_centroid_mpt_idl_3|0101000020E610000000000000007066C00000000000000000
+geog_centroid_mpt_idl_1|POINT(180 0)
+geog_centroid_mpt_idl_2|POINT(179.5 0)
+geog_centroid_mpt_idl_3|POINT(-179.5 0)
 geog_centroid_pt_self_1|0101000020E610000000000000000010400000000000002040
 geog_centroid_pt_self_2|0101000020E61000000000000000002EC00000000000003040
 geog_centroid_pt_self_3|0101000020E610000000000000000037C000000000000045C0
Summary of changes:
 regress/core/geography_centroid.sql | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
