[postgis] compilation error
Ross.Searle Ross.Searle at dnr.qld.gov.au
Wed Aug 15 16:51:06 PDT 2001
Paul/Frank
Thanks. Worked a treat. Pretty obvious when I stop and think about it.
Regards
Ross
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Thursday, 16 August 2001 1:43 AM
To: postgis at yahoogroups.com
Subject: Re: [postgis] compilation error
Welcome to Solaris :) for some reason the compilation tools are hidden
away outside of normal paths.
Do this command (if you are using csh):
set path = ( $path /usr/ccs/bin )
and then try again.
Ross.Searle at dnr.qld.gov.au wrote:
> Hi,
> I am trying to compile postgis on a Solaris 6 box using GCC and GNU make.
I
> keep getting the following error and as I don't know make speak I was
> wondering if anyone could point me in the right direction.
> gcc  -Wall -Wmissing-prototypes -Wmissing-declarations -fPIC -g  -I.
> -I../../src/include  -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/etc"'  -c
-o
> postgis_proj.o postgis_proj.c
> ar crs libpostgis.a postgis_debug.o postgis_ops.o postgis_fn.o
> postgis_inout.o postgis_proj.o
> gmake: ar: Command not found
> gmake: *** [libpostgis.a] Error 127
> Thanks
> Ross
> The information in this e-mail together with any attachments is
> intended only for the person or entity to which it is addressed
> and may contain confidential and/or privileged material.
> Any form of review, disclosure, modification, distribution
> and/or publication of this e-mail message is prohibited.
> If you have received this message in error, you are asked to
> inform the sender as quickly as possible and delete this message
> and any copies of this message from your computer and/or your
> computer system network.
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
