[postgis] text -> geometry ?
Michael Scharber mscharber at josh.ucsd.edu
Fri Aug 24 11:46:37 PDT 2001
Hi there,
Can anyone help me understand how to assign a geometry field a value that
is not a string literal?  In plpgsql I'm trying the following from within
a trigger'd function:
update <table>
  set <geom_field> = ''POINT('' || x || '' '' || y || '' '' || z || '')''
  where <field> = <some_value>;
where x, y and z are float8 types.
I've also tried the following in psql directly:
update <table>
  set <geom_field> = 'POINT(' || '1' || ' ' || '2' || ' ' || '3' || ')'
In both cases I get
  "ERROR:  Attribute 'shape' is of type 'geometry' but expression is of type 'text'
        You will need to rewrite or cast the expression"
so I tried ('POINT(' || '1' || ' ' || '2' || ' ' || '3' || ')')::geometry
and got "ERROR:  Cannot cast type 'text' to 'geometry'".
I just started using Postgres, and PostGIS for that matter, yesterday so
I'm hoping someone can point out the blunder I'm making.
Thanks in advance.
Michael
      	Michael Scharber
	Scripps Institution of Oceanography
	Institute of Geophysics and Planetary Physics
	8785 Biological Grade
	IGPP Room 4212
	La Jolla, CA 92037
	(858)534-1750
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Get VeriSign's FREE GUIDE: "Securing Your Web Site for Business." Learn about using SSL for serious online security. Click Here!
http://us.click.yahoo.com/KYe3qC/I56CAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
