[postgis] distance(geometry,geometry) function
Tue Jul 24 12:30:03 PDT 2001
"Timothy H. Keitt" wrote:
> Not in general, no.  This is all made more complex by the fact that
> postgis points and polygons are not seperate SQL types, but are instead
> mixed together within a single column of type "geometry", so you have to
> make your function accept all types of geometry objects.  I'm curious
> why you chose this path instead of making each geometric type a
> different SQL type as with the built-in postgresql geometry types?
Tim,
Dave may want to add to this, but the approach of having a base geometry
type is essentially inherited from the OpenGIS simple features geometry
model.  In particular, for OGC simple features it is necessary to be
able to mix geometry types within a given column in a given table.
If we implement the full Simple Features for SQL metadata (via auxilary
tables) there will be a mechanism to indicate that particular tables
are restricted to a particular subtype in the total set of possible
geometry types.
>  Come
> to think of it, I'm not sure what postgis provides that the built-in
> types don't (except maybe much faster queries?).
Holes in polygons, geometry collections and 3d (really 2.5D) support
are the obvious extensions available in the PostGIS geometry model.
Best regards,
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Small business owners...
Tell us what you think! http://promo2.yahoo.com/sbin/Yahoo!_BusinessNewsletter/survey.cgi
http://us.click.yahoo.com/vO1FAB/txzCAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
