[postgis] distance(geometry,geometry) now in the CVS version
Dave Blasby dblasby at refractions.net
Tue Jul 24 13:47:37 PDT 2001
The distance() function is now in the CVS version.
I've also put in expand(BOX3D,double d) which returns a new bbox which
is exanded d unit in all directions.
ie.
select expand('BOX3D(0 0 0, 100 100 100)', 100.0);
              expand
 BOX3D(-100 -100 -100,200 200 200)
(1 row)
also, because there's an auto-convesion between geometry and box3d, you
can;
select expand('POINT(0 0 0)'::GEOMETRY, 100.0);
              expand
 BOX3D(-100 -100 -100,100 100 100)
This will allow you to do an index search using distances more easily.
Lets say you take "A" as your base feature you're searching for nearby
objects;
select * from <table> where  distance(A,<geom_col>) <100 and
<geom_col> && expand(A, 100) ;
<geom_col> && expand(A, 100):
	this does an index scan on the table looking for features that might be
100 units or less away from A.  It'll quickly filter out far away
features.
	this returns true if the min distance from A to the geometry is less
than 100 units
dave
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Small business owners...
Tell us what you think! http://promo2.yahoo.com/sbin/Yahoo!_BusinessNewsletter/survey.cgi
http://us.click.yahoo.com/vO1FAB/txzCAA/ySSFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
