[postgis] Distance on a Spheroid
Dave Blasby dblasby at refractions.net
Wed Jun 27 14:50:16 PDT 2001
We had requests to do length calculations on a spheroid.  They are now
available, thanks to Mark Sondheim and David Skae at Geographic Data BC.
New type, SPHEROID.  Specify in OpenGIS WKT format.
SPHEROID("name",<semi-major axis>, <inverse flattening)
ie. SPHEROID("GRS_1980",6378137,298.257222101)
as per the WKT spec, you can use "[]" instead of "()"
If your geometry is in LAT/LONG format you can use:
length3d_ellipsoid(GEOMETRY, SPHEROID)
	-- find the length of all the LINESTRINGs in GEOMETRY
length_ellipsoid  (GEOMETRY, SPHEROID)
	-- find the length of all the LINESTRINGs in GEOMETRY, ignoring
		Z values.
for example,
select length_spheroid('LINESTRING(-126 49,-126 49.011096139863)',
'SPHEROID["GRS_1980",6378137,298.257222101]');
	gives 1234.000
dave
ps. I'm using the X coordinate to mean Longitude and Y to mean Lattitude
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
