[postgis] Is there any solution to exceed the limit of PGLIB
TONY J.Y. tjiang at mrf.com
Tue Nov 27 07:22:48 PST 2001
I am using the PGLIB C lib to connect to PgSql to finish the update of
the GEOMETRY of a table.
At first, everything is OK. I can insert, update, delete and select of
whatever I want.
However, I got a fatal running error.  There is an error when my SQL
string length exceeds 8190 Bytes.
Obviously, this is not the limits of the PgSQL itsself. It is the PGLIB.
Is there any solution or suggestion?
Thanks.
------------------------ Yahoo! Groups Sponsor ---------------------~-->
E-mail viral marketing - with FastTree
Email to 50. You might reach 500.
Unlimited use and tracking, $20/mo.
http://www.fasttree.com/s/11.htm
http://us.click.yahoo.com/UGVLpD/MJRDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
