[postgis] Arcview script
Per-Olof Norén pelle at alma.nu
Tue Oct 2 05:35:19 PDT 2001
Hisaji,
Could you please run a diff (using "diff -u <from-file> <to-file>") on the
file you changed?
thx in advance
/Per-Olof Norén
----- Original Message -----
To: <Ross.Searle at dnr.qld.gov.au>
Cc: <postgis at yahoogroups.com>
Sent: Tuesday, October 02, 2001 2:34 PM
Subject: Re: [postgis] Arcview script
> Hello.
>  Thank you very much, Mr. Ross..
> Your avenue script has helped me, because shp2pgsql sometimes couldn't
> succeed to convert some large size polygon or line shapefiles.
>  This scripts works fine, but it seemed not to support multipolygons even
> these exist in the choice menu in your script.
>  I 've changed the following part in your script to support multipolygons.
> for each rec in theftab
>   shp = thefTab.ReturnValue(thefTab.FindField("Shape"), rec).aspolygon
>   partlist = shp.aspolygon.aslist
>   'shpstr = x.setformat("dddddddd").asstring + 9.aschar + thefeat+"((("
>   shpstr = x.setformat("dddddddd").asstring + 9.aschar + thefeat+"(("
> modified
>   for each part in partlist
>     ii = 0                      '<--- added
>     shpstr = shpstr + "("'<--- added
>     'for each p in part
>     for each i in 0..(part.count - 2) '<--- modified
>       p = part.get(i) '<--- modified
>       shpstr = shpstr + p.getX.setformat("d.dddddd").asstring + " " +
> p.getY.setformat("d.dddddd").asstring +", "
>     end
>      p = part.get(part.count - 1) '<--- added
> p.getY.setformat("d.dddddd").asstring + ")" '<--- added
>     ii = ii + 1 '<--- added
>     if (ii < partlist.count) then '<--- added
>       shpstr = shpstr + "," '<--- added
>     end '<--- added
>   end
>   'polystr = shpstr.left(shpstr.count - 2) + ")))" + 9.aschar
>   polystr = shpstr.left(shpstr.count) + "))" + 9.aschar   '<--- modified
>  Please tell me if you have any comment about this.
> > Hi,
> > We recently had some problematic shapefiles which shp2psql wouldn't
> > process due to some topology problems in the shapefile. We couldn't
> > track them down so I ended up writing an avenue script to produce a dump
> > text file from a shapefile. It is rough and ready but does the job.
> > shp2psql is much quicker but I thought I'd make it available in case
> > anyone had a use for it.
> > Ross
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Get your FREE VeriSign guide to security solutions for your web site: encrypting transactions, securing intranets, and more!
http://us.click.yahoo.com/UnN2wB/m5_CAA/yigFAA/PhFolB/TM
