[postgis] Querying mapserver with data from PostGIS table
Paul Ramsey pramsey at refractions.net
Fri Oct 5 07:48:22 PDT 2001
Use lower case for the attribute names:
[description] fpr example...
Paul
Ewa Patrowicz <ewap at arges.pl> said:
> I have a situation:
> - shape "xxx" with attributies :
>    geometry, ident, description
> I constructed map layer
> LAYER
>   NAME "ss"
>   DATA "xxx"
>   HEADER "xxx_hdr.htm"
>   TEMPLATE "xxx_tmpl.htm"
>   FOOTER "xxx_ftr.htm"
>   CLASS
>   END
> END
> When querying this layer I obtained good results. For example
> "1-st description"
> "2-nd description"
> "71-th description"
> Trouble is when I try using postgis table
>  - table "xxxx" with columns :
> Table contained the same data as the shape above.
> LAYER
>   NAME "sss"
>   CONNECTIONTYPE postgis
>   CONNECTION ...
>   DATA "geometry FROM xxxx"
>   CLASS
>   END
> END
> I used the same template query files xxx_*.htm as the names of columns and attributies were the same.
> When querying this layer I obtained a list of labels instead of values.
> Using the same circumstances :
> [DESCRIPTION]
> [DESCRIPTION]
> [DESCRIPTION]
> What could I do for obtaining the correct result in this situation?
> Ewa.
  Paul Ramsey
  Refractions Research Inc
  (250) 885-0632
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Pinpoint the right security solution for your company- Learn how to add 128- bit encryption and to authenticate your web site with VeriSign's FREE guide!
http://us.click.yahoo.com/yQix2C/33_CAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
