[postgis] Re: problem when install on redhat 86
lzw63china lzw63china at yahoo.com
Sun Oct 14 19:28:10 PDT 2001
I'm so sorry that I have not installed the postgresql7.1.2 correctly.
I have make completely install of the redhat 7.1(that include the
postgressql7.0.3), then I installed the postgresql7.1.2, and stop the
old version by :
/etc/rc.d/init.d/postgresql stop  (redhat provided shell)
and run the postgresql by :
postmaster -D /usr/local/pgsql &
but this may be run the old version, I don't know where the old
version is installed.
The right use of new version of 7.1.2 is
/usr/local/pgsql/bin/initdb -D /usr/local/pgsql/data
/usr/local/pgsql/bin/postmaster -D /usr/local/pgsql/data &
after do that I have successfully installed the postgis( all
version), and can run it well.
thank you very much for help me!
--- In postgis at y..., Paul Ramsey <pramsey at r...> wrote:
> More information please :) Hardware is not at issue, the precise
steps
> you went through in compiling and installing are, as are the exact
error
> conditions you are seeing.
> P.
> lzw63china at y... wrote:
> > I can't install the postgis on my machine.
> > my hardware is x86 with 128M memory
> >    software : redhat7.1 with postgresql-7.1.2(default install)
> > when i finished install the postgis version > 0.1,   I can't
finish
> >      psql -d mydatabase < postgis.sql
> > the error message is abort.
> > When I install the postgis-0.1, I can do it well, I can create
table
> > with geometry field, but I can't insert the geometry value to the
> > table, the error message is file load fail of libpostgis.so.0.1.
> > To unsubscribe from this group, send an email to:
> > postgis-unsubscribe at y...
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
