[postgis] postgis_undef.sql incomplete ??
Dave Blasby dblasby at refractions.net
Thu Oct 18 09:40:39 PDT 2001
Manuel Weindorf wrote:
> I guess there should be the following commands added to postgis_undef.sql
> somewhere:
postgis_undef.sql is auto-generated by the command "perl create_undef.pl
postgis.sql".  I thought it was in the makefile to automatically be
called when postgis.sql is changed.
Paul will make (no pun intended) this change and commit.
I changed the perl script to also delete the two meta-information
tables.
Thanks for the bug report,
dave
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
