[postgis] PostGIS 0.6 installation on Windows NT
Hisaji ONO ono96 at fa2.so-net.ne.jp
Tue Sep 25 08:13:27 PDT 2001
 Hi, Monsieur Ribbon.
 Currently I'm running PostgreSQL 7.1.3 with PostGIS 0.6.0 on Windows NT
Server Ver. 4.0 SP6a + security patches(CPU Pentium III 800MHZ, Memory
256MB.)
 In http://postgresql.nucba.ac.jp/related.html, two links of documents about
compiling sources of PostgreSQL 7.1.x and installing it on Windows2000 or
NT.
 I'll follow the instruction of latter one,
http://www.sevainc.com/PostgreSQL_running_on_NT.html on above site.
 Did you install Cygwin32 IPC package which is required for running
PostgreSQL on Cygwin?
 For compiling PostGIS 0.6, I've met following two problems.
 First, I must comment out two functions in postgis_debug.c.
 Second, for compiling new dumper, pgsql2shp.c, this Makefile couldn't find
specified path of libraries, which only exist in installed directory, not
exist in source directory.Probably I installed PostgreSQL binaries before
making PostGIS, so PostgreSQL's Makefile's intstall didn't remain them in
source directory. So I must directly specify path of libraries for compiling
this code.
 Hopefully this will help you.
> Hello,
> I'm trying to install PostGis 0.6 on Windows NT.
> I successfully installed PostGreSQL 7.1.1 with PostgreSQLServer.exe
> (I tried to install Cygwin and to configure PostGreSQL, but did not
> succeed. So I downloaded the exe and installed it. Then it worked: I can
> manage the DB with Zeos Database Explorer or phpPgAdmin)
> I would like to have some tips or examples to compile and run postGis on
> NT.
> Thanx a lot.
> Nicolas Ribot.
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Get your FREE VeriSign guide to security solutions for your web site: encrypting transactions, securing intranets, and more!
http://us.click.yahoo.com/XrFcOC/m5_CAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
